    Duet2 + SBC + Additional drivers
    544
    • MartinNYHCundefined
      MartinNYHC
      I need 3 additional drivers for a Duet2 which is running in SBC mode. I just recognized that the Duet Expansion Breakout Board is also connected via the expansion header. Are there any other options to connect a SBC and expansion board together to a Duet2?
      Thanks, Martin
        jay_s_uk @MartinNYHC
        @martinnyhc how have you connected the SBC? typically it is through the ethernet breakout boards pins and not the expansions header
        MartinNYHCundefined 1 Reply Last reply Reply Quote 0
          MartinNYHC @jay_s_uk
          @jay_s_uk said in Duet2 + SBC + Additional drivers:
          I'm usually usisng Duet3 boards. Where can I find some more informations please?
            @martinnyhc i'm confused now. are you using a duet 2 or a duet 3? post some photos of your setup
            MartinNYHCundefined 1 Reply Last reply Reply Quote 1
              This one is a Duet2 Ethernet which was lying around in the shelf for two years now 🙂
                @martinnyhc in which case, the SBC connects to the ethernet headers so the expansion header is free, so theres nothing stopping you connecting a duex5 or a breakout board to the duet 2
                MartinNYHCundefined 2 Replies Last reply Reply Quote 0
                  That's good news. Thanks.
                    I also have a spare Duet3 Mini 5+. What option do I have with this board when using SBC and additional drivers?
                      @martinnyhc you can add an additional 2 drivers directly to the board. after that its using CAN-FD boards such as the toolboard and 3HC
                        @jay_s_uk OK, but the Mini 2+ will be connected to expansion headers where the SBC is already connected to?!
                          @martinnyhc no, it has its own header
                            @jay_s_uk NOW i got it 🙂 I think that's the way for me.
