    Input debounce setting
    Gcode meta commands
    • baird1fa
      baird1fa last edited by
      Hello everyone. I’m wondering if there is any way to adjust or set a debounce filter on an input pin.
      I have a filament runout sensor running on a duet 3 and randomly the print will pause because it thinks it ran out of filament. It in fact hasn’t so I think there is some electrical interference that occasionally triggers the input. For my application I don’t need something that reads a low to high signal the instant it happens but rather a change that is sustained for at least 1 second. That would help eliminate false triggers.
      Another example, I have a duet 2 WiFi running a CMC router I built and I’m using a push button to launch my tool probe macro (it sets the z height). But I have found that it can be erroneously triggered by my M8 (coolant on) relay signals. It is just electrical noise that randomly triggers it. But again a 1second filter would work great.
      Is there anything like that? I would think it would be a debounce setting.
      Thanks.
      OwenD 1 Reply Last reply Reply Quote 0
      • OwenD
        OwenD @baird1fa last edited by OwenD
        @baird1fa
        You can use conditional gcode to achieve this in your filament-error.g file
        Note: This assumes you're running RRF 3.4
        The names are different in earlier versions.
        In this case I'm using a small delay and checking that the sensor is now indicating "OK" which would mean it's bouncing.
        You could just as easily use a longer delay and reverse the logic to make sure the sensor status is still "not OK"
        G4 P10 ; delay 10ms to debounce
        if sensors.filamentMonitors[0].status="ok"
        	echo "switch bounce detected - error cancelled"
        	M99 ; break out of macro if sensor value is zero again (bouncing)
        EDIT:
        For your CNC just check the value of the GPIn using the same method
        if sensors.gpIn[6].value=0
        baird1fa 1 Reply Last reply Reply Quote 2
        • Moved from General Discussion by  Phaedrux Phaedrux
        • baird1fa
          baird1fa @OwenD last edited by
          @owend said in Input debounce setting:
          G4 P10 ; delay 10ms to debounce if sensors.filamentMonitors[0].status="ok" echo "switch bounce detected - error cancelled" M99 ; break out of macro if sensor value is zero again (bouncing)
          This seems to have worked. I haven't fully tested it yet, also I needed add a filament-error.g where I put this code (incase someone comes across this post in the future) I was just using the pause.g for the filament runout.
