    Warranty enquiry
    Purchasing
    • Nightowl
      Nightowl last edited by Nightowl
      When using the Out 7 header with one of the supplied two-pin plugs, it was quite loose when I connected the plug and didn't seem to click in. When I removed the plug to take a look, I noticed the locking tab was loose and, when I looked closer and tried to connect the plug, the clip fell off.
      This is going to be difficult for you to believe maybe, but this is honestly the first time I've used that header (there is a thread here explaining my adventures with using a relay!), so I've changed the code to use Out 8, but that's quite loose too, and I'm a bit reluctant to go any further in case more locking tabs break. Obviously, this means Out 7 is now out of use.
      The headers I've used for the four stepper motors, proximity switches and power connectors connect quite firmly.
      Should I request support from the supplier (Ooznest) or are you able to assist with this, please?
      The order was placed on the 21st February 2022.
      Thank you.
      EDIT: I appreciate it's a(nother!) bank holiday weekend so I'm not expecting an immediate response, but I'm wondering if this may be related to the (apparently) intermittent issue I'm having trying to get the relay to operate 😖
      Few things are more dangerous than taking the advice of someone who thinks he knows what he's doing.
      I'm still on my learning curve, so take everything I say with caution!
      RatRig 1075, Duet3 MB6HC, Sorotec SFM 1000 PV-ER milling motor, Hobbyist
        Please send an email to warranty@duet3d.com and CC your reseller. Include a link to this forum thread and the details of your original purchase. You'll receive a reply with a form to fill out.
        Nightowl 1 Reply Last reply Reply Quote 0
        • Nightowl
          Nightowl @Phaedrux last edited by
          Hi @phaedrux,
          Thanks for your reply. I sent a message to Ooznest earlier today and they've just replied asking for a photo, too.
          Should I wait for their response before I do as you ask?
            • Nightowl
              Thank you to Support (and @Phaedrux) for helping me with this issue, which is now fully resolved.
