    Spindle Control on 6HC
    CNC
    604
    • Xamationundefined
      Xamation
      Re: Spindle Controll with M950
      Hello everybody,
      i can't drive a spindle with a duet 3D 6HC
      I used a frequency-voltage converter card on output Out9 (Laser / VFD) but I can't detect any PWM signal.
      the config file is the following:
      ; Configuration file for Duet 3 (firmware version 3.3)
      ; generated by RepRapFirmware Configuration Tool v3.3.10 on Fri Dec 17 2021 15:27:41 GMT+0100 (Ora standard dell’Europa centrale)
      M575 P1 S1 B57600                       ; enable support for PanelDue
      G90                                     ; send absolute coordinates...
      M453                           			; CNC Mode
      M83                                    ; ...but relative extruder moves
      M550 P"XAM-CNC01"                      	; set printer name
      M929 P"logEventi.txt" S1
      M552 P192.0.0.47 S1                     ; enable network and acquire dynamic address via DHCP
      M553 P255.255.255.0						; set netmask
      M554 P192.0.0.1							; set gateway
      M586 P0 S1                              ; enable HTTP
      M586 P1 S0                              ; disable FTP
      M586 P2 S0                              ; disable Telnet
      M569 P0.0 S1                            ; physical drive 0.0 goes forwards
      M569 P0.1 S1                            ; physical drive 0.1 goes forwards
      M569 P0.2 S1                            ; physical drive 0.2 goes forwards
      M584 X0.0 Y0.1 Z0.2 P3            		; set drive mapping
      M350 X16 Y16 Z16 I1		                ; configure microstepping with interpolation
      M92 X640.00 Y640.00 Z640.00 E420.00     ; set steps per mm
      M566 X900.00 Y900.00 Z60.00 E120.00     ; set maximum instantaneous speed changes (mm/min)
      M203 X600.00 Y6000.00 Z180.00 E1200.00  ; set maximum speeds (mm/min)
      M201 X50.00 Y50.00 Z20.00 E250.00       ; set accelerations (mm/s^2)
      M906 X800 Y800 Z800 E800 I30            ; set motor currents (mA) and motor idle factor in per cent
      M84 S30                                 ; Set idle timeout
      M208 X0 Y0 Z0 S1                        ; set axis minima
      M208 X395 Y600 Z70 S0                   ; set axis maxima
      M574 X1 S1 P"!io1.in" 					; configure active-low endstop for low end on X via pin io0.in
      M574 Y1 S1 P"!io2.in"					; configure active-low endstop for low end on Y via pin io1.in
      M574 Z1 S1 P"!io3.in" 					; configure active-low endstop for low end on Z via pin io3.in
      M558 P0 H5 F120 T6000                   ; disable Z probe but set dive height, probe speed and travel speed
      M557 X15:215 Y15:195 S20                ; define mesh grid
      ; Inserito ultimamente
      M563 P0 F0								; define tool 0
      G10 P0 X0 Y0 U0 Z0						; set tool 0 axis offset
      G10 P0 R0 S0							; set initial tool 0 active and standby temperature to 0C
      ; CNC
      M950 F8 C"nil"							; free up fan out 8
      M950 F7 C"nil"							; free up fan out 7
      M950 R0 C"OUT9+!io4.out+out7" L24000   ; configure CNC mode and set PWM+ON/FWD+REV R set max spindle RPM
      G54
      M564 S H0
      M575 P1 S1 B57600
      the sequence of operations I do is as follows:
      I turn on the device;
      I connect to the Duet IP address;
      I make the zero point of all the axes;
      I set the RPM of the Spindle 0 to 10000
      I try to send and press the OFF key corresponding to Active but nothing happens
      Thanks to those who can help me
      Angelo
      dc42undefined Nightowlundefined 2 Replies Last reply Reply Quote 0
        dc42 administrators @Xamation
        @xamation you need to declare the spindle using M950 before you create the tool, then when you create the tool using M563 include the R spindle number parameter. After selecting the tool using T0 you should be able to control the spindle.
        Xamationundefined 1 Reply Last reply Reply Quote 1
        • Xamationundefined
          Xamation @dc42
          @dc42 Hi,
          I updated the code so you suggested me.
          The config file is updated with the M950 and then M563 commands.
          Everything still doesn't work. I also changed the string M568 P0 F0 with
          M568 P0 F1000 but it does not go.
          ; CNC Mode (Firmware 3.3)
          M453         										; CNC Mode
          ;Configure Tool 0 as the CNC Spindle
          M950 R0 C"OUT9+!io4.out+out7" Q2000 L0:25400	 	; Create spindle index 0, PWM frequency 2KHz, max rpm = 25.4K ( tweaked to yield 24K)
          												   	; and the following connections:
          													; 	spindle speed PWM pin	: exp.9 pin
                                                              ;	spindle run pin 		: exp.4
                                                              ;	spindle direction pin 	: exp.7
          M563 P0 R0 S"Spindle"                              	; Create Tool 0 with Spindle 0 and call it Spindle
          G10  P0 X0 Y0 Z0                                    ; Set Tool 0 axis offsets
          M568 P0 F0										; Set Tool 0 to default RPM of 0
          T0													; Select Tool 0
          G54
          M564 S H0
          M575 P1 S1 B57600
          Where am I wrong?
            Phaedrux Moderator @Xamation
            @xamation said in Spindle Control on 6HC:
            Where am I wrong?
            Can you send M98 P"config.g" to check the syntax?
            Xamationundefined 1 Reply Last reply Reply Quote 0
            • Xamationundefined
              Xamation @Phaedrux
              @phaedrux @phaedrux in the config file I have not entered any M98 command.
              To activate the spindle, after turning on the machine, I make the zero point of all the axes (X,Y,Z) and send the command M3 P0 S1000 through the web interface
              jay_s_ukundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
                jay_s_uk @Xamation
                @xamation this is my spindle section from my config.
                M453
                M950 R0 C"e0heat+e1heat+e2heat" Q100 L6000:24000				; CNC mode and spindle settings
                M563 P0 R0 S"Spindle"                              				; define tool 0
                and i can control the spindle ok using M3 etc.
                sending m3 s6000 turns the spindle on at 6000 RPM.
                  You misunderstand me. What I want you to do is send M98 P"config.g" in the gcode console in DWC and copy and paste the response you get here so we can see if there are any syntax errors in your config.
                  • Xamationundefined
                    Xamation @Phaedrux
                    @phaedrux I solved the promise. I installed the update to version 3.4 and it seems to work. I updated some commands but it reports the error: Error: bad drive number
                      Can you be more specific? Show us what you changed.
                      • Nightowlundefined
                        Nightowl @Xamation
                        Hi @xamation,
                        Would you be kind enough to explain why you have three pin names in the M950 line for the spindle like this so I can understand why, please
                        I'm very new to 'programming' the Duet3, but I'm wondering if this (which I haven't tested yet because my milling motor hasn't arrived) will work:
                        ; AMB spindle configuration
                        M950 R0 C"out9" L0:25000 Q1000 ; create spindle with index 0
                        M563 P1 S"Spindle 1" R0 ; create tool 1 with spindle 0 and name it "Spindle 1"
                        M453 ; set machine to CNC mode
                        T1 ; select tool 1
                        M3 S0
                        M5 ; stop spindle
                        Thank you.
                        Few things are more dangerous than taking the advice of someone who thinks he knows what he's doing.
                        I'm still on my learning curve, so take everything I say with caution!
                        RatRig 1075, Duet3 MB6HC, Sorotec SFM 1000 PV-ER milling motor, Hobbyist
                          jay_s_uk @Nightowl
                          @nightowl999 the first pin sets the speed using PWM, second one sets the spindle to forward, 3rd one sets the spindle to reverse
                          Nightowlundefined 1 Reply Last reply Reply Quote 0
                          • Nightowlundefined
                            Nightowl @jay_s_uk
                            Thanks, @jay_s_uk.
                            OK, so I'm guessing (assuming everything's configured correctly) the g-code file sends an M3 S2000 command, for example, and the first configured pinout would signal that to the spindle to turn on and run at 2000rpm.
                            I don't envisage (!) ever using the spindle to rotate in any direction other than its default rotational direction, so I shouldn't need to use the other two pinouts, should I?
                              jay_s_uk @Nightowl
                              @nightowl999 the second pin enables the spindle
                              • Nightowlundefined
                                Nightowl @jay_s_uk
                                @jay_s_uk Got it, thanks.
