    Toolboard V1.2 Heater 1 fault: failed to read sensor: bad Vssa
    • CR3Dundefined
      CR3D
      Dear Community,
      I have some problems with an Toolboard.
      after everything worked initially, a heater fault was displayed from one moment to the next. A Phaetus Rapido HF Hotend is installed.
      Following Error Message:
      Error: Heater 1 fault: failed to read sensor: bad Vssa
      I disconnected the heater and thermistor and also used the second thermistor channel. No chance.
      Here is the M122 B20:
      I've reset the board and reinstalled the firmware. RRF 3.4.0 is used
      Do you have any idea?
      Is the Toolboard faulty?
      Regards Christian
      Christian from CR-3D
      Homepage:
      www.cr-3d.de
      Facebook:
      https://www.facebook.com/cr3d.official
      Our Discord Server
      https://discord.gg/SxRaPNuRdA
      Thingiverse Profile:
      https://www.thingiverse.com/cr-3d_official/about
      oliofundefined dc42undefined 2 Replies Last reply Reply Quote 0
      • oliofundefined
        oliof @CR3D
        @cr3d that photo is way too unclear regarding heater and thermistor wiring to make any call. Have you tried swapping the toolboards between the two tool heads?
        CR3Dundefined 1 Reply Last reply Reply Quote 0
          dc42 administrators @CR3D
          @cr3d I've seen this problem once before. If there is a short between the hot end heater and the ground side of the thermistor, then the VSSA fuse is supposed to protect the board. Unfortunately, the 10 ohm resistor R47 may blow before the VSSA fuse kicks in. So if you have a multimeter, I suggest you check resistor R47.
          • CR3Dundefined
            CR3D @oliof
            @dc42 thank you i will check the resistor 🙂
            Homepage:
            www.cr-3d.de
            Facebook:
            Our Discord Server
