    BL Touch Probes Extremely Slowly
    488
    • TRATOONundefined
      TRATOON
      Hello, I got my Ender 5 Plus up and running yesterday with a Duet 2 Wifi. When I started a print, all the axes were going really slow, during homing and BL Touch probing. How do I fix this?
      ; Configuration file for Duet WiFi (firmware version 3.3)
      ; generated by RepRapFirmware Configuration Tool v3.3.10 on Thu Apr 21 2022 23:00:27 GMT-0700 (Pacific Daylight Time)
      M575 P1 S1 B57600                                    ; enable support for PanelDue
      G90                                                    ; send absolute coordinates...
      M83                                                    ; ...but relative extruder moves
      M550 P"Ender 5 Plus"                                   ; set printer name
      M552 S1                                                ; enable network
      M586 P0 S1                                             ; enable HTTP
      M586 P1 S0                                             ; disable FTP
      M586 P2 S0                                             ; disable Telnet
      M569 P0 S1                                             ; physical drive 0 goes backwards
      M569 P1 S1                                             ; physical drive 1 goes backwards
      M569 P2 S0                                             ; physical drive 2 goes forwards
      M569 P3 S0                                             ; physical drive 3 goes forwards
      M584 X0 Y1 Z2 E3                                       ; set drive mapping
      M350 X16 Y16 Z16 E16 I1                                ; configure microstepping with interpolation
      M92 X80.00 Y80.00 Z800.00 E409.00                      ; set steps per mm
      M566 X600.00 Y600.00 Z30.00 E1200.00                   ; set maximum instantaneous speed changes (mm/min)
      M203 X9000.00 Y9000.00 Z480.00 E7200.00                ; set maximum speeds (mm/min)
      M201 X1500.00 Y1500.00 Z100.00 E6000.00                ; set accelerations (mm/s^2)
      M906 X800 Y800 Z800 E1100 I30                          ; set motor currents (mA) and motor idle factor in per cent
      M84 S30                                                ; Set idle timeout
      M208 X20 Y20 Z0 S1                                     ; set axis minima
      M208 X320 Y320 Z350 S0                                 ; set axis maxima
      M574 X2 S1 P"xstop"                                    ; configure switch-type (e.g. microswitch) endstop for high end on X via pin xstop
      M574 Y2 S1 P"ystop"                                    ; configure switch-type (e.g. microswitch) endstop for high end on Y via pin ystop
      M950 S0 C"exp.heater3"                                 ; create servo pin 0 for BLTouch
      M558 P9 C"^zprobe.in" H5 F1800 T12000                  ; set Z probe type to bltouch and the dive height + speeds
      G31 P500 X-41 Y-2 Z3.112                               ; set Z probe trigger value, offset and trigger height
      M557 X35:215 Y35:195 S20                               ; define mesh grid
      M308 S0 P"bedtemp" Y"thermistor" T100000 B4725         ; configure sensor 0 as thermistor on pin bedtemp
      M950 H0 C"bedheat" T0                                  ; create bed heater output on bedheat and map it to sensor 0
      M307 H0 B0 S1.00                                       ; disable bang-bang mode for the bed heater and set PWM limit
      M140 H0                                                ; map heated bed to heater 0
      M143 H0 S100                                           ; set temperature limit for heater 0 to 100C
      M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin e0temp
      M950 H1 C"e0heat" T1                                   ; create nozzle heater output on e0heat and map it to sensor 1
      M307 H1 B0 S1.00                                       ; disable bang-bang mode for heater  and set PWM limit
      M143 H1 S300                                         ; set temperature limit for heater 1 to 300C
      M950 F0 C"fan0" Q500                                   ; create fan 0 on pin fan0 and set its frequency
      M106 P0 S0 H-1                                         ; set fan 0 value. Thermostatic control is turned off
      M950 F1 C"fan1" Q500                                   ; create fan 1 on pin fan1 and set its frequency
      M106 P1 S255 H1 T45:150                                ; set fan 1 value. Thermostatic control is turned on
      M563 S"Nozzle" P0 D0 H1 F0 ; tool 0 uses extruder drive 0, heater 1 and fan 0 (part cooling fan)
      G10 P0 X0 Y0 Z0                                        ; set tool 0 axis offsets
      G10 P0 R0 S0                                           ; set initial tool 0 active and standby temperatures to 0C
      M501                                                   ; load saved parameters from non-volatile memory
      • fcwiltundefined
        fcwilt @TRATOON
        @tratoon
        The speed limits set in M203 are respected when using the Z probe.
        So even though you specify a speed of F1800 in the M558 command the speed of 480 in the M203 limits the speed.
        480 is rather slow - where did that number come from? It looks like you may be using a 4mm lead lead screw or some equivalent setup.
        TRATOONundefined 2 Replies Last reply Reply Quote 0
        • TRATOONundefined
          TRATOON @fcwilt
          @fcwilt I found that number online
          • TRATOONundefined
            TRATOON @fcwilt
            @fcwilt And it's not just the Z-Axis, whenever I start a print and it starts to home it is very slow when compared to homing it manually.
            • TRATOONundefined
              TRATOON
              @fcwilt I just changed Z Axis to 500. I got that number from somebody else's config for ender 5 plus (The Z axis on E5 Plus is really slow) And it was all the axis that were going slow not just the z
              • fcwiltundefined
                fcwilt @TRATOON
                @tratoon said in BL Touch Probes Extremely Slowly:
                I would need to see your homing code. The Z axis speed might be limiting homing.
                As a reference the Z axis max speed for all my printers is 1200.
                • TRATOONundefined
                  TRATOON
                  I just changed the 500 in m203 to 1200
                  ; homeall.g
                  ; called to home all axes
                  ; generated by RepRapFirmware Configuration Tool v3.3.10 on Sat Apr 30 2022 23:00:17 GMT-0700 (Pacific Daylight Time)
                  G91                   ; relative positioning
                  G1 H2 Z5 F6000        ; lift Z relative to current position
                  G1 H1 X285 Y285 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
                  G1 H2 X-5 Y-5 F6000   ; go back a few mm
                  G1 H1 X285 Y285 F360  ; move slowly to X and Y axis endstops once more (second pass)
                  G90             ; absolute positioning
                  G1 X175 Y175 F6000 ; go to first probe point
                  G30             ; home Z by probing the bed
                  ;G91                  ; relative positioning
                  ;G1 Z5 F100           ; lift Z relative to current position
                  ;G90                  ; absolute positioning
                  ; homex.g
                  ; called to home the X axis
                  ; generated by RepRapFirmware Configuration Tool v3.3.10 on Thu Apr 21 2022 23:00:28 GMT-0700 (Pacific Daylight Time)
                  G1 H1 X345 F1800 ; move quickly to X axis endstop and stop there (first pass)
                  G1 H2 X-5 F6000  ; go back a few mm
                  G1 H1 X345 F360  ; move slowly to X axis endstop once more (second pass)
                  G1 H2 Z-5 F6000  ; lower Z again
                  ; homey.g
                  ; called to home the Y axis
                  G1 H1 Y345 F1800 ; move quickly to Y axis endstop and stop there (first pass)
                  G1 H2 Y-5 F6000  ; go back a few mm
                  G1 H1 Y345 F360  ; move slowly to Y axis endstop once more (second pass)
                  ; homez.g
                  ; called to home the Z axis
                  ; generated by RepRapFirmware Configuration Tool v3.3.10 on Sat Apr 30 2022 22:44:38 GMT-0700 (Pacific Daylight Time)
                  Also why is it that only when its printing it homes slowly, but when I press the Home All in DWC it works fine? Could it be the GCODE File?
                  • fcwiltundefined
                    fcwilt @TRATOON
                    @tratoon
                    It could be. Some slicers have an option to change printer settings, like max speed.
                    I always disable that feature, if it exists.
                    You can post the first 50 lines of so of a file you are printing - it will likely be obvious from examining the code if the slicer is messing with your settings.
                    TRATOONundefined 1 Reply Last reply Reply Quote 0
                    • TRATOONundefined TRATOON marked this topic as a question
                    • TRATOONundefined TRATOON has marked this topic as solved
                    • TRATOONundefined TRATOON has marked this topic as unsolved
                    • TRATOONundefined
                      TRATOON @fcwilt
                      @fcwilt
                      ;FLAVOR:RepRap
                      ;TIME:146379
                      ;Filament used: 178.503m
                      ;Layer height: 0.2
                      ;MINX:121.595
                      ;MINY:35.455
                      ;MINZ:0.2
                      ;MAXX:303.405
                      ;MAXY:304.545
                      ;MAXZ:37
                      ;Generated with Cura_SteamEngine 4.12.1
                      T0
                      M190 S55
                      M104 S195
                      M109 S195
                      M82 ;absolute extrusion mode
                      M201 X500.00 Y500.00 Z100.00 E5000.00 ;Setup machine max acceleration
                      M203 X500.00 Y500.00 Z10.00 E50.00 ;Setup machine max feedrate
                      M204 P500.00 R1000.00 T500.00 ;Setup Print/Retract/Travel acceleration
                      M205 X8.00 Y8.00 Z0.40 E5.00 ;Setup Jerk
                      M220 S100 ;Reset Feedrate
                      M221 S100 ;Reset Flowrate
                      G28 ;Home
                      G29 ; Start BL-Touch Probing Sequence
                      M420 S1 Z2 ;Enable ABL using saved Mesh and Fade Height
                      G92 E0 ;Reset Extruder
                      G1 Z2.0 F3000 ;Move Z Axis up
                      G1 X10.1 Y20 Z0.28 F5000.0 ;Move to start position
                      G1 X10.1 Y200.0 Z0.28 F1500.0 E15 ;Draw the first line
                      G1 X10.4 Y200.0 Z0.28 F5000.0 ;Move to side a little
                      G1 X10.4 Y20 Z0.28 F1500.0 E30 ;Draw the second line
                      M83 ;relative extrusion mode
                      G1 F2400 E-0.5
                      ;LAYER_COUNT:185
                      ;LAYER:0
                      M107
                      M204 T500
                      ;MESH:20220402_Kavi_Gupta_Bottom_Base_Type_01.stl(2)
                      G0 F15000 X174.977 Y158.881 Z0.2
                      M204 P10000
                      ;TYPE:WALL-INNER
                      G1 F2400 E0.5
                      G1 F12000 X176.08 Y158.783 E0.03683
                      G1 X177.149 Y158.497 E0.03681
                      G1 X178.153 Y158.029 E0.03684
                      G1 X179.06 Y157.394 E0.03683
                      G1 X179.844 Y156.609 E0.0369
                      G1 X180.478 Y155.704 E0.03675
                      G1 X180.947 Y154.697 E0.03695
                      G1 X181.232 Y153.631 E0.0367
                      G1 X181.33 Y152.525 E0.03693
                      G1 X181.232 Y151.424 E0.03676
                      G1 X180.945 Y150.352 E0.03691
                      G1 X180.478 Y149.352 E0.03671
                      G1 X179.841 Y148.442 E0.03695
                      G1 X179.06 Y147.661 E0.03674
                      G1 X178.153 Y147.026 E0.03683
                      G1 X177.149 Y146.558 E0.03684
                      G1 X176.08 Y146.272 E0.03681
                      G1 X174.974 Y146.175 E0.03693
                      G1 X173.873 Y146.272 E0.03676
                      G1 X172.804 Y146.558 E0.03681
                      G1 X171.798 Y147.027 E0.03692
                      G1 X170.892 Y147.664 E0.03684
                      G1 X170.11 Y148.444 E0.03674
                      G1 X169.474 Y149.354 E0.03693
                      G1 X169.006 Y150.358 E0.03684
                      G1 X168.721 Y151.424 E0.0367
                      G1 X168.624 Y152.528 E0.03686
                      G1 X168.722 Y153.634 E0.03693
                      G1 X169.007 Y154.7 E0.0367
                      G1 X169.476 Y155.706 E0.03692
                      G1 X170.112 Y156.612 E0.03682
                      G1 X170.894 Y157.394 E0.03678
                      G1 X171.801 Y158.029 E0.03683
                      G1 X172.804 Y158.497 E0.03681
                      G1 X173.873 Y158.783 E0.03681
                      G1 X174.977 Y158.881 E0.03686
                      G0 F15000 X174.977 Y158.479
                      ;TYPE:WALL-OUTER
                      G1 F12000 X176.01 Y158.388 E0.03449
                      G1 X177.012 Y158.12 E0.0345
                      G1 X177.952 Y157.681 E0.03451
                      G1 X178.802 Y157.086 E0.03451
                      G1 X179.536 Y156.351 E0.03455
                      G1 X180.13 Y155.503 E0.03444
                      G1 X180.57 Y154.56 E0.03461
                      G1 X180.837 Y153.561 E0.03439
                      G1 X180.928 Y152.525 E0.03459
                      G1 X180.837 Y151.494 E0.03442
                      G1 X180.568 Y150.49 E0.03457
                      G1 X180.13 Y149.553 E0.0344
                      G1 X179.533 Y148.7 E0.03463
                      G1 X178.802 Y147.969 E0.03438
                      G1 X177.952 Y147.374 E0.03451
                      G1 X177.012 Y146.935 E0.03451
                        Phaedrux Moderator @TRATOON
                        Your slicer has these speed limiting commands in it's start gcode section. Remove them from the slicer.
                        TRATOONundefined 1 Reply Last reply Reply Quote 1
                        • TRATOONundefined
                          TRATOON @Phaedrux
                          @phaedrux Now whenever I change the initial layer speed it doesn't work, and prints it at normal speed, which causes adhesion problems.
                          • fcwiltundefined
                            fcwilt @TRATOON
                            Where are you changing that layer speed? It should be in the slicer.
                            • TRATOONundefined
                              TRATOON @fcwilt
                              @fcwilt It is in the slicer
