    G-code for only "Filament Extrusion" without moving nozzle
    Gcode meta commands
    1.0k
    • Asif Istiakundefined
      Asif Istiak
      I need to extrude filament in a fixed amount for a certain time by the 3D printer without moving the nozzle to any axis.
      I have applied the code like this(mentioned below) but as soon as I run the code, the nozzle stops.
      What's the problem with my code?
      Is there any instance of a modified G-code to meet my need?
      Thanks in advance.
      Code-
      G21 ; set units to millimeters
      M104 S200 ; set temperature
      M106
      M109 S200 ; wait for temperature to be reached
      G90 ; use absolute coordinates
      G92 E0
      M82 ; use absolute distances for extrusion
      G1 Z0.0 F5.000
      G1 Y1.000 E0.0100000
      G1 Y1.000 Z0.00 E1.00000 F2.000
      G1 Y0.000 Z0.00 E1.00000 F2.000
      G92 E0
      M107
      M104 S0
      M107
      G91
      G90
      • fcwiltundefined
        fcwilt @Asif Istiak
        @asif-istiak
        You are using M82 which is absolute, as noted in the comment.
        You have G1 command with E0.01 which will "move" the extruder to position 0.01
        Then you have a G1 command with E1.00 which will "move" the extruder to position 1.00
        The next five G1 commands with E1.00 don't "move" the extruder since it is already at position 1.00
        And you should not need to include the Y and Z parameters unless you want to change the Y and Z position.
        Try using M83 which is relative.
        A G1 E1 command should extrude 1 mm.
        A G1 E100 command should extrude 100 mm.
        Asif Istiakundefined 1 Reply Last reply Reply Quote 0
          Asif Istiak @fcwilt
          @fcwilt thanks.
          How about this?
          M106
          G92 E0
          M83
          G1 E1.00000 F2.000
          G1 E1.00000 F2.000
          G1 E1.00000 F2.000
          G1 E1.00000 F2.000
          G1 E1.00000 F2.000
          G1 E1.00000 F2.000
          G1 E1.00000 F2.000
          G1 E1.00000 F2.000
          G1 E1.00000 F2.000
          G1 E1.00000 F2.000
          G1 E1.00000 F2.000
          G1 E1.00000 F2.000
          G92 E0
          M107
          M104 S0
          M107
          G91
          G90
          • BoAundefined
            BoA
            https://forum.duet3d.com/topic/28401/g-code-for-only-filament-extrusion-without-moving-nozzle
            Same question in 2 places, and 3 minutes between posting them... damn I thought I am the impatient guy 😉
            Asif Istiakundefined 1 Reply Last reply Reply Quote 1
            • fcwiltundefined
              fcwilt @Asif Istiak
              @asif-istiak
              That should work but is there a reason for twelve G1 E1.00 commands instead of one G1 E12.00 ?
                Asif Istiak @fcwilt
                @fcwilt Yes, it is working.
                Yes, I am looking for the least amount of extrusion.
                What will happen if I do not insert F in the code?
                fcwiltundefined 1 Reply Last reply Reply Quote 1
                  Asif Istiak @BoA
                  @boa Sorry, I did not understand while posting. However, thanks a lot for your answer. It is working
                  • fcwiltundefined
                    fcwilt @Asif Istiak
                    @asif-istiak said in G-code for only "Filament Extrusion" without moving nozzle:
                    It should use the F value from the last command where F was included.
                    Asif Istiakundefined 2 Replies Last reply Reply Quote 0
                      Asif Istiak @fcwilt
                      @fcwilt Thank you
                        Asif Istiak @fcwilt
                        @fcwilt Hi, is there any modification of code to make the extrusion to the slowest speed?
                        M106
                        G92 E0
                        M83
                        G1 E12.00000 F2.000
                        G92 E0
                        M107
                        M104 S0
                        M107
                        G91
                        G90
                        • fcwiltundefined
                          fcwilt @Asif Istiak
                          The slowest speed? I guess that would be determined by the type of variable used to hold the F value. It's a floating point number but I have no idea what the precision is.
                          @dc42 would be the one to answer that question.
                            You can use M203 I to specify a lower minimum speed. The default minimum speed is 30mm/min which is already quite slow.
                            https://docs.duet3d.com/User_manual/Reference/Gcodes#m203-set-maximum-feedrate
                            How slow do you need it to go?
                            G1 E12.00000 F2.000
                            12mm at 2mm/min will take 24 minutes to complete. Is that what you're expencting?
                              Asif Istiak @Phaedrux
                              @phaedrux thanks for the answer. But, I am expecting the ''lowest'' extrusion rate from the nozzle which will run for 30min without moving. May I have your suggestion on that?
                                Phaedrux Moderator @Asif Istiak
                                I'm not sure what you mean by this.
                                If you want to run slower than 30mm/min you will need to set the minimum speed manually by changing your M203 command in config.g to include an I value. For example, M203 I1 would give you 1mm/min.
                                  @phaedrux I just need to extrude the filament; in that time the nozzle will not move to any axis.
                                  And, the rate of the extrusion will be the least
                                    ok... I'm still confused by what you're actually trying to accomplish.
                                    • fcwiltundefined
                                      fcwilt @Asif Istiak
                                      Well the smallest value you can specify is I1 in the M203.
                                        @phaedrux I want to make fiber from that not any 3D printed object
                                          Asif Istiak @fcwilt
                                          @fcwilt So, is that like this?
                                          M106
                                          G92 E0
                                          M83
                                          G1 M203 I1 E15.00000 F2.000
                                          G92 E0
                                          M107
                                          M104 S0
                                          M107
                                          G91
                                          G90
                                          fcwiltundefined deckingmanundefined 2 Replies Last reply Reply Quote 0
                                          • fcwiltundefined
                                            fcwilt @Asif Istiak
                                            M106
                                            G92 E0
                                            M83
                                            G92 E0
                                            M107
                                            M104 S0
                                            M107
                                            G91
                                            G90
                                            No. M203 is typically in your config.g file.
                                            if the M203 already has the I parameter change the existing value to 1.
                                            If the M203 doesn't already have the I parameter just add it with the value of 1.
                                            Then re-boot the printer or reset the Duet to cause the new config values to take effect.
