    15500 Hz Whine at idle
    • Dezdoghoundundefined
      Dezdoghound
      When I leave my printer idle for more than 30 minutes, it starts making a 15,500 Hz sound that's quite prominent and goes away with any load (eg heater on). Interested as to what causes this, I assume it's some sort of standby state from either the duet or the power supply itself?
      Just curious if there's anything I can do to stop it. My (or my dog's!) ears don't appreciate it 😉
      dc42undefined Falkiaundefined 2 Replies Last reply Reply Quote 0
        dc42 administrators @Dezdoghound
        @dezdoghound my guess is that the whine is coming from your power supply.
        • Falkiaundefined
          Falkia @Dezdoghound
          @dezdoghound as @dc42 mentioned I think this is from the power supply. It is common that a switched power supply generates a whining sound when no load is applied.
          /Fredrik
          Printer: "Deltacus" Delta with 510mm bed diameter and 925mm build height. Powered by Duet 2 WiFi. Duet Smart Effector with E3D Volcano.
