z axis homing fails... it just keeps clicking
X and y home fine. When I home z, Z0 does fine, while Z1 keeps clicking and bouncing.
@the-chairman said in z axis homing fails... it just keeps clicking:
Please don't overwhelm us with details.
Please copy-and-paste your config.g file and the various "homing" files - use the </> tag - one tag per file.
Thanks.
@fcwilt Thanks for the input. I tried copying code on my phone yesterday and the forum gave me an error. A friend suggested that I run m119 in the console and it showed the z stop as being off. I looked over the wiring this morning to discover that the z probe cable was plugged into the wrong spot on the Duet. Problem solved.
I am trying to suss out my Crealty CR Touch, but I'll start another thread on it when I'm ready for input.
@fcwilt I'm having an issue with search on this forum. I'm trying to find how to set up the Crealty CR Touch and not coming up with much.
@the-chairman Got to BLTouch at https://docs.duet3d.com/en/User_manual/Connecting_hardware/Z_probe_connecting Creality has different wiring.
@the-chairman it looks like it's more or less compatible with BLTouch, see https://www.crealityofficial.co.uk/blogs/buyer_guides/bltouch-vs-cr-touch. If you configure it as for a BLTouch and it still doesn't work, I suggest you create a new thread.
undefined dc42 marked this topic as a question
undefined dc42 has marked this topic as solved
@dc42 Thanks! I am currently getting this error:
G32 Error: Probe already triggered before probing move started
I'm not even sure I have it wired correctly, but I think I do.
I'll check out that link in a bit and see if I can suss it out from there.
