    Phase A and B may be disconnected
    • Chownki
      Chownki last edited by
      Hey - Got an older prusa mk2.5s with a duet 2 wifi, it have been running fine for months, but now when im doing G32 ill get "Warning: Driver 0 warning: phase a may be disconnected, phase B may be disconnected"
      Driver 0 is my X axis and its running fine. I have checked all wires and connector all seems fine, not sure what else to look for?
      m122
      RepRapFirmware for Duet 2 WiFi/Ethernet version 3.4.0 (2022-03-15 18:58:31) running on Duet WiFi 1.02 or later
      Board ID: 0JD0M-9P6B2-NJ4S4-6J9F8-3SD6S-TV1GM
      Used output buffers: 3 of 24 (14 max)
      Static ram: 23868
      Dynamic ram: 74768 of which 12 recycled
      Never used RAM 10432, free system stack 118 words
      Tasks: NETWORK(ready,32.5%,243) HEAT(notifyWait,0.1%,332) Move(notifyWait,0.0%,295) MAIN(running,67.4%,460) IDLE(ready,0.1%,30), total 100.0%
      Owned mutexes: WiFi(NETWORK)
      Last reset 02:08:50 ago, cause: power up
      Last software reset at 2022-05-11 20:30, reason: User, GCodes spinning, available RAM 13360, slot 1
      Error status: 0x00
      Aux0 errors 0,0,0
      Step timer max interval 0
      MCU temperature: min 24.8, current 35.5, max 39.4
      Supply voltage: min 10.6, current 12.1, max 12.5, under voltage events: 0, over voltage events: 0, power good: yes
      Heap OK, handles allocated/used 99/0, heap memory allocated/used/recyclable 2048/108/108, gc cycles 0
      Events: 7 queued, 7 completed
      Driver 0: standstill, SG min 0
      Driver 1: standstill, SG min 0
      Driver 2: standstill, SG min 0
      Driver 3: standstill, SG min n/a
      Driver 4: standstill, SG min 0
      Driver 5:
      Driver 6:
      Driver 7:
      Driver 8:
      Driver 9:
      Driver 10:
      Driver 11:
      Date/time: 2022-05-12 19:12:06
      Slowest loop: 11.25ms; fastest: 0.19ms
      === Storage ===
      Free file entries: 10
      SD card longest read time 4.0ms, write time 0.0ms, max retries 0
      DMs created 83, segments created 6, maxWait 429259ms, bed compensation in use: none, comp offset 0.000
      === MainDDARing ===
      Scheduled moves 244, completed 244, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 1], CDDA state -1
      === AuxDDARing ===
      Segments left: 0
      Movement lock held by null
      HTTP is idle in state(s) 0
      Telnet is idle in state(s) 0
      File is idle in state(s) 0
      USB is idle in state(s) 0
      Aux is idle in state(s) 0
      Trigger is idle in state(s) 0
      Queue is idle in state(s) 0
      LCD is idle in state(s) 0
      Daemon is idle in state(s) 0
      Code queue is empty
      === Network ===
      Slowest loop: 15.71ms; fastest: 0.00ms
      Responder states: HTTP(2) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions
      HTTP sessions: 1 of 8
      • WiFi -
        Network state is active
        WiFi firmware version 1.26
        WiFi MAC address e0:98:06:22:e6:1c
        WiFi Vcc 3.39, reset reason Turned on by main processor
        WiFi flash size 4194304, free heap 24800
        WiFi IP address 192.168.1.6
        WiFi signal strength -66dBm, mode 802.11n, reconnections 0, sleep mode modem
        Clock register 00002002
        Socket states: 4 0 0 0 0 0 0 0
      Pumlux Phaedrux 2 Replies Last reply Reply Quote 0
      • Pumlux
        Pumlux @Chownki last edited by
        @chownki
        I had some similar error messages on my Duet 2 Wifi months ago.
        All was working fine and suddenly some phases may be disconnected.
        To make it short, in my case the connection of the stepper was weak.
        I checked it a couple of times and I thought the connections is fine, but when looking in detail, the crimping on the cable was not perfect and I could pull the cable out of the contact shoe.
        To be 100% save I soldered the cable to the connector shoe and this error message did not appear again.
        So shame on my crimping style.
        You may check with a complete new cable on your driver giving the error message.
        Using a own build of a Mendel Max , Duet Wifi, Bed 8 mm Aluminium PEI 500 x 280 x 400 230 V 850 W, original E3D Chimera hotend with bowden length 700 mm, since short time with a BL-Touch, Steppers : mostly Nema 17 and one Nema 23 for Y-axis
          Phaedrux Moderator @Chownki last edited by
          @chownki said in Phase A and B may be disconnected:
          What speed are you moving at when you get the errors?
          Chownki 1 Reply Last reply Reply Quote 0
          • Chownki
            Chownki @Phaedrux last edited by
            @phaedrux
            I was running at F12000, used those speeds on my a mk3 with E3D 48mm steppers, guess the orginal prusa steppers dont like those speeds, when i drop to F8000 errors are gone.
            Do you know if its because the steppers are missing steps ill get those errors?
              dc42 administrators @Chownki last edited by
              @chownki it's because the inductance and back emf of those motors exceeds the power supply voltage at those speeds. When this happens, the motor positioning becomes less accurate, and the motor gets noisier.
              If you are using 12V power in your machine then upgrading to 24V will allow higher speeds, although of course this normally requires different the heaters and fans.
              Use our motor calculator at https://www.reprapfirmware.org/emf.html to estimate the maximum speed before the supply voltage becomes insufficient.
