    Loading a file
    Duet Web Control
    • Nightowlundefined
      Nightowl
      Silly question or I've missed something...
      Where do I load a g-code file into DWC without it starting (which it does, if I use Upload and Start), so I can preview it with the g-code viewer before I run it?
      Thanks
      Few things are more dangerous than taking the advice of someone who thinks he knows what he's doing.
      I'm still on my learning curve, so take everything I say with caution!
      RatRig 1075, Duet3 MB6HC, Sorotec SFM 1000 PV-ER milling motor, Hobbyist
        jay_s_uk @Nightowl
        @nightowl999 jobs tab and then upload gcode
        Nightowlundefined 1 Reply Last reply Reply Quote 1
        • Nightowlundefined
          Nightowl @jay_s_uk
          @jay_s_uk
          Hmm, I thought I did that, but nothing showed in the viewer.
          I'll check again, thank you 👍
            jay_s_uk @Nightowl
            @nightowl999 you may need to hit the up refresh button
            • Nightowlundefined
              Nightowl
              Nope, I don't think I've got it!
              I uploaded a toolpath g-code file but I see nothing in the g-code viewer, other than the coloured arrows showing the axes.
              There is a way to review the job in the DWC before starting it, I assume?
              Stephen6309undefined 1 Reply Last reply Reply Quote 0
              • Stephen6309undefined
                Stephen6309 @Nightowl
                @nightowl999 Easiest way: Right click the file for the 3d gcode viewer.
