    Connect 24v led to duet3 6hc with 3hc
    • Cavemanundefined
      Caveman
      Where can I safely connect a 24v led strip to one of my boards. Have a duet3 6hc with 3hc expension board. it lives in a e3d toolchanger and want to l make a nozzle light
        dc42 administrators @Caveman
        @caveman assuming you are using 24V VIN power to the 6HC and the 3HC, I suggest you connect the strip to any spare high-current OUT port on either the 6HC or the 3HC.
        If the strip draws no more than about 1A then the low current OUT ports are also suitable, assuming the voltage for that port is set to VIN and not to 12V.
        Cavemanundefined 1 Reply Last reply Reply Quote 0
        • Cavemanundefined
          Caveman @dc42
          @dc42 @dc42 is it posibble to pwm high current ouptput?
            jay_s_uk @Caveman
            @caveman yes
