    Toolboard v1.3, compatible with the Hemera XS
    • T3P3Tonyundefined
      T3P3Tony administrators
      We have developed a version of the Duet 3 Toolboard 1LC, version 1.3, which has the hole positions compatible with the Hemera XS.
      Other than the hole position changes no functionality has been removed and the overall board dimensions are the same. In addition the RRP is the same.
      We will continue to make the v1.2 toolboards for some time as some of our customers are already using that form factor and will need time to change to the new hole spacing. For new projects we recommend using the v1.3 boards.
      We have already started to send some of these boards to our distributors.
      The documentation is updated here: with the revision history, new dimensions etc:
      https://docs.duet3d.com/en/Duet3D_hardware/Duet_3_family/Duet_3_Toolboard_1LC
      The e3d provided files for mounting the board on Hemera XS on the tool changer are not yet done however as the XS makes its way out to the community hopefully we will see a solution there soon.
      www.duet3d.com
      elmoretundefined mattyoundefined 2 Replies Last reply Reply Quote 1
      • T3P3Tonyundefined T3P3Tony referenced this topic
      • elmoretundefined
        elmoret @T3P3Tony
        Available at Filastruder:
        https://www.filastruder.com/products/duet3toolboard1lc
        • mattyoundefined
          mattyo @T3P3Tony
          @t3p3tony Could you tell me if you know if any have been sent out to Australian distributors. Thanks Matt
          • T3P3Tonyundefined
            T3P3Tony administrators @mattyo
            @mattyo not yet, please feel free to ask Aurarum to stock them!
            www.duet3d.com
