    Changing Acceleration Midprint
    807
    • 3DPrintingWorldundefined
      3DPrintingWorld
      It is possible to change acceleration values for the X and Y axis during a print, either from the command prompt or by inserting it into the G-code? The goal is to change accelerations for a ringing test.
        dc42 administrators @3DPrintingWorld
        @3dprintingworld yes that's possible. The standard way to change XY accelerations during a print is to use the M204 command, however M201 cold also be used.
        3DPrintingWorldundefined 1 Reply Last reply Reply Quote 0
          3DPrintingWorld @dc42
          @dc42 That's what I thought but does not seem to be working for me. I'm trying to increase the accel by 1000 every 25 layers starting at 2000.
          Config
          M201 X2000.00 Y2000.00 Z500.00 E600.00
          Inserted on line 25 of gcode
          M201 X3000.00 Y3000.00
          I also tried M204 like this.
          Config
          Inserted on line 25
          M204 P3000.00 T3000.00
          It does not look like its increasing, plus layer times are not decreasing. Is there a way to check the current acceleration setting?
            Phaedrux Moderator @3DPrintingWorld
            @3dprintingworld said in Changing Acceleration Midprint:
            Yes, send M201 by itself and it will report back the current value.
            Is your slicer inserting it's own values?
            Are your extruder settings holding things back perhaps?
              3DPrintingWorld @Phaedrux
              @phaedrux Thanks, that will make it easy to verify.
              When searching the g-code the only M201 or 204 I find is the ones I inserted.
              "The extruder holding it back", like its accelerations are not fast enough to keep up with the travel moves? I can increase it and try.
              Fred-Yundefined 1 Reply Last reply Reply Quote 0
              • Fred-Yundefined
                Fred-Y @3DPrintingWorld
                @3dprintingworld you can also use a macro called on a layer change using the command M98.
                The idea was to be able to adjust the values without having modify manually a gcode file or modify the gcode in the slicer every time.
                Below is a script (requires RRF3+) I used longtime ago, I'm not sure at 100% it works but you have a base to play with.
                It can be easily improved with a loop or to also test the Jerk or even Input Shaping values.
                var mbase = 7000
                var macc = {var.mbase}
                if move.axes[2].machinePosition >= 55
                	set var.macc = {var.mbase}+5500
                elif move.axes[2].machinePosition >= 50
                	set var.macc = {var.mbase}+5000
                elif move.axes[2].machinePosition >= 45
                	set var.macc = {var.mbase}+4500
                elif move.axes[2].machinePosition >= 40
                	set var.macc = {var.mbase}+4000
                elif move.axes[2].machinePosition >= 35
                	set var.macc = {var.mbase}+3500
                elif move.axes[2].machinePosition >= 30
                	set var.macc = {var.mbase}+3000
                elif move.axes[2].machinePosition >= 25
                	set var.macc = {var.mbase}+2500
                elif move.axes[2].machinePosition >= 20
                	set var.macc = {var.mbase}+2000
                elif move.axes[2].machinePosition >= 15
                	set var.macc = {var.mbase}+1500
                elif move.axes[2].machinePosition >= 10
                	set var.macc = {var.mbase}+1000
                else
                M201 X{var.macc} Y{var.macc}
                3DPrintingWorldundefined 1 Reply Last reply Reply Quote 1
                  3DPrintingWorld @Fred-Y
                  @fred-y That's really smart, I just put a dumb script in my slicer at layer height.
                    3DPrintingWorld
                    Thanks for the help! It turns out changing M201 worked perfectly fine from the start. I expected to see a larger amount of ringing between accelerations but I was printing fast enough as I forgot to turn up perimeter under speed.
