    Fine editor for working with Duet boards
    Third-party software
    13
    50
    3.5k
    • fcwiltundefined
      fcwilt
      As the capabilities of the Duet firmware have expanded so has the number and complexity of .G files that I am installing on the Duet boards.
      The limitations of the DWC editor make creating/maintaining these files less than "fun".
      I have been using a Windows based editor for years now, for general text file creating/editing (as opposed to a document creation/editing tool like Word).
      I recently looked into the capabilities of this editor to deal with files on an FTP server. The Duet firmware offers the needed FTP services.
      I am happy as a clam at high tide. I have all the power of this editor and it makes dealing with the files being on the Duet about as simple as could be expected.
      If anyone is interested I could go into greater detail.
      Nightowlundefined 1 Reply Last reply Reply Quote 2
      • Nightowlundefined
        Nightowl @fcwilt
        @fcwilt
        Did I miss something? What editor are you using?
        Few things are more dangerous than taking the advice of someone who thinks he knows what he's doing.
        I'm still on my learning curve, so take everything I say with caution!
        RatRig 1075, Duet3 MB6HC, Sorotec SFM 1000 PV-ER milling motor, Hobbyist
        fcwiltundefined 1 Reply Last reply Reply Quote 1
        • fcwiltundefined
          fcwilt @Nightowl
          @nightowl999 said in Fine editor for working with Duet boards:
          @fcwilt
          It's a general purpose text editor that I have been using for years. It's a bit quirky but very powerful.
          My text editor
          It supports FTP. So I setup an FTP connection for each of my printers.
          Briefly it works like this:
          • open the FTP connection and it downloads all of the files from the folder on the Duet that you specified in the FTP connection entry, say, the sys folder.
          • it displays those file names in a list on the left of the editor
          • double-click on a file and it shows up in the edit window on the right of the editor
          • after finishing the editing you save the file and it is uploaded to the Duet
          You can enable a couple of "backup features:
            1. makes a backup on the Duet itself before it uploads the edited file.
            1. keeps a copy of the all the files on the Duet in a folder on your computer.
          I have both those features enabled.
          Now I have climbed the learning curve on this editor a long time ago. All I needed to learn was how to connect to the Duet via FTP. Everything else is very much like editing a set of files right on the computer.
          I am very happy with how it all works.
          Nightowlundefined 1 Reply Last reply Reply Quote 0
            Oh wow, I used to use EditPad in the early 2000s
            Lately I've been using Sublime Text on my Macbook as it has direct sync to Github and a good gcode syntax highlighter. Looks like it also has FTP sync, though I haven't tried that.
            Nightowlundefined 1 Reply Last reply Reply Quote 1
            • Nightowlundefined
              Nightowl @fcwilt
              @fcwilt
              That reminds me of similar software from Windows 3.1 days, but I can't remember the name! The interface is a bit like WinZip.
              I don't think my use of it would justify the cost of Fine Editor, though - I'm happy (for now) to stick with the DWC as I have nowhere near as many as you! 🤣
              • Nightowlundefined
                Nightowl @Phaedrux
                @phaedrux said in Fine editor for working with Duet boards:
                Sublime Text
                Strewth, programs like these used to be free!
                  Phaedrux Moderator @Nightowl
                  Sublime Text
                  It still is free, or more accurately, Nagware. It prompts you to buy it occasionally.
                  • fcwiltundefined
                    fcwilt @Nightowl
                    @fcwilt
                    Windows 3.1? You've been around a while.
                    You might surprise yourself as you find all the new and interesting things you can do given the features they keep adding to the firmware.
                    From time to time something like this that costs a bit (in this case $60) is mentioned and others express the concern about spending the money. But stop and think about the real cost of 3D printing. I don't want to think about how much money I have spent on filament. That $60 might only buy 2-3 spools of good quality filament. 😄
                    What motivated me was a desire to use a more consistent naming scheme for files and variables.
                    And to replace smallish blocks of code appearing in multiple places with a M98 call to a new file with that same block of code.
                    Using a "real" editor made making all those changes a relatively painless process.
                    • Nightowlundefined
                      Nightowl @fcwilt
                      @fcwilt said in Fine editor for working with Duet boards:
                      How rude! 🤣 🤣
                      • fcwiltundefined
                        fcwilt @Nightowl
                        How rude! 🤣 🤣
                        I use to use CP/M and actually did some productive work with it. Back then having a machine with 64K of memory was hot stuff.
                        I also remember trying to use Windows 1.x and 2.x and how primitive they were.
                        As I recall 3.x was the first with decent networking.
                        We've come a long way.
                        • Nightowlundefined
                          Nightowl @fcwilt
                          I use to use CP/M
                          You've probably been around longer than me, then!
                          JuJuDeltaundefined 1 Reply Last reply Reply Quote 1
                          • JuJuDeltaundefined
                            JuJuDelta @Nightowl
                            Intel's Aedit running on MS-DOS was the best!
                            8" floppies, MCS-51 Dev system on wheels the size of a fridge.
                            And before that punched tape and cards!
                            You didn't run programs, you submitted them as a batch file overnight, to then find out you made a typo!
                            You "Younglings" are spoilt 🙂
                            T3DP3D Kossel XL+, Duet2Wifi, PanelDue 7i, RRF V3.2, Fl3xdrive, SmartEffector, Berd Air annulus, Cura 4.x, PrusaSlicer, RPi WiFi Camera, Heated Chamber
                            Nightowlundefined fcwiltundefined Coffeeundefined 3 Replies Last reply Reply Quote 3
                            • Nightowlundefined
                              Nightowl @JuJuDelta
                              @jujudelta Haha!
                              I do remember taking hours to programming a Sinclair ZX80 for it to beep, and finding I'd mis-typed something - or the magazine I'd tried to copy it from had an important piece of code cut with staples!
                              • fcwiltundefined
                                fcwilt @JuJuDelta
                                @jujudelta said in Fine editor for working with Duet boards:
                                My first "programming" was on IBM accounting machines. You inserted a bunch of jumper wires from one hole to another, on a big "patch panel", to control what the machines did.
                                They couldn't do very much but they were large and loud!
                                And when the rest of my friends were at schools learning Fortran I was learning ALGOL, of which I remember absolutely nothing.
                                infiniteloopundefined 1 Reply Last reply Reply Quote 1
                                • infiniteloopundefined
                                  infiniteloop @fcwilt
                                  My first micro had a "keyboard" with two buttons and 2x8 DIP switches: one DIP to enter the address, the other to enter a data byte. The red button transferred a byte into one of the 256 bytes of RAM, the green button ran the program. As display, I had 8 LEDs.
                                  • fcwiltundefined
                                    fcwilt @infiniteloop
                                    @infiniteloop said in Fine editor for working with Duet boards:
                                    That must of been kind of tedious.
                                    But it sounds something like an Intel microprocessor development system we had, which had a bunch of switches on the front. I remember we used them to enter the "boot loader" which then could read in the actual program from a paper tape reader.
                                    infiniteloopundefined 1 Reply Last reply Reply Quote 0
                                      Don't worry, the next machine I could work with was a IBM 5100 😉
                                      • mikeabuilderundefined
                                        mikeabuilder
                                        I still have a prototype HP Intel 486 machine in my basement. It was really hot stuff at the time. My processor was double clocked - from 20Mhz to 40Mhz. That was hot stuff in it's time, about 30 years ago.
                                        • fcwiltundefined
                                          fcwilt @mikeabuilder
                                          @mikeabuilder said in Fine editor for working with Duet boards:
                                          Fun times for sure. I remember upgrading an IBM desktop from 4 to 6-8 Mhz - heady stuff.
                                          Who dreamed where we would be today with gigahertz clock speeds, gigabytes of memory and terabytes of solid state drives.
                                          • OwenDundefined
                                            OwenD
                                            @fcwilt
                                            Looks good 👍
                                            I have been using a free editor called
                                            RJ Texted.
                                            It also has FTP, but I haven't used it.
                                            I did a syntax file that allows auto completion and does mouse over help hints for existing files.
                                            https://forum.duet3d.com/topic/14637/reprap-g-code-syntax-now-part-of-rj-texted-text-editor/2?_=1654136072761
                                            The syntax file is no longer included as standard because it was changing too quickly.
                                            I see that you can do syntax highlighters in your editor as well, so it would be good for someone to do so.
                                            I looked at doing one for Notepad ++ but it was to clunky
