    Fine editor for working with Duet boards
    Third-party software
    13
    50
    3.6k
      Oh wow, I used to use EditPad in the early 2000s
      Lately I've been using Sublime Text on my Macbook as it has direct sync to Github and a good gcode syntax highlighter. Looks like it also has FTP sync, though I haven't tried that.
      Nightowlundefined 1 Reply Last reply Reply Quote 1
      • Nightowlundefined
        Nightowl @fcwilt
        @fcwilt
        That reminds me of similar software from Windows 3.1 days, but I can't remember the name! The interface is a bit like WinZip.
        I don't think my use of it would justify the cost of Fine Editor, though - I'm happy (for now) to stick with the DWC as I have nowhere near as many as you! 🤣
        Few things are more dangerous than taking the advice of someone who thinks he knows what he's doing.
        I'm still on my learning curve, so take everything I say with caution!
        RatRig 1075, Duet3 MB6HC, Sorotec SFM 1000 PV-ER milling motor, Hobbyist
        • Nightowlundefined
          Nightowl @Phaedrux
          @phaedrux said in Fine editor for working with Duet boards:
          Sublime Text
          Strewth, programs like these used to be free!
            Phaedrux Moderator @Nightowl
            @nightowl999 said in Fine editor for working with Duet boards:
            Sublime Text
            It still is free, or more accurately, Nagware. It prompts you to buy it occasionally.
            • fcwiltundefined
              fcwilt @Nightowl
              @fcwilt
              Windows 3.1? You've been around a while.
              You might surprise yourself as you find all the new and interesting things you can do given the features they keep adding to the firmware.
              From time to time something like this that costs a bit (in this case $60) is mentioned and others express the concern about spending the money. But stop and think about the real cost of 3D printing. I don't want to think about how much money I have spent on filament. That $60 might only buy 2-3 spools of good quality filament. 😄
              What motivated me was a desire to use a more consistent naming scheme for files and variables.
              And to replace smallish blocks of code appearing in multiple places with a M98 call to a new file with that same block of code.
              Using a "real" editor made making all those changes a relatively painless process.
              • Nightowlundefined
                Nightowl @fcwilt
                @fcwilt said in Fine editor for working with Duet boards:
                How rude! 🤣 🤣
                • fcwiltundefined
                  fcwilt @Nightowl
                  How rude! 🤣 🤣
                  I use to use CP/M and actually did some productive work with it. Back then having a machine with 64K of memory was hot stuff.
                  I also remember trying to use Windows 1.x and 2.x and how primitive they were.
                  As I recall 3.x was the first with decent networking.
                  We've come a long way.
                  • Nightowlundefined
                    Nightowl @fcwilt
                    I use to use CP/M
                    You've probably been around longer than me, then!
                    JuJuDeltaundefined 1 Reply Last reply Reply Quote 1
                    • JuJuDeltaundefined
                      JuJuDelta @Nightowl
                      Intel's Aedit running on MS-DOS was the best!
                      8" floppies, MCS-51 Dev system on wheels the size of a fridge.
                      And before that punched tape and cards!
                      You didn't run programs, you submitted them as a batch file overnight, to then find out you made a typo!
                      You "Younglings" are spoilt 🙂
                      T3DP3D Kossel XL+, Duet2Wifi, PanelDue 7i, RRF V3.2, Fl3xdrive, SmartEffector, Berd Air annulus, Cura 4.x, PrusaSlicer, RPi WiFi Camera, Heated Chamber
                      Nightowlundefined fcwiltundefined Coffeeundefined 3 Replies Last reply Reply Quote 3
                      • Nightowlundefined
                        Nightowl @JuJuDelta
                        @jujudelta Haha!
                        I do remember taking hours to programming a Sinclair ZX80 for it to beep, and finding I'd mis-typed something - or the magazine I'd tried to copy it from had an important piece of code cut with staples!
                        • fcwiltundefined
                          fcwilt @JuJuDelta
                          @jujudelta said in Fine editor for working with Duet boards:
                          My first "programming" was on IBM accounting machines. You inserted a bunch of jumper wires from one hole to another, on a big "patch panel", to control what the machines did.
                          They couldn't do very much but they were large and loud!
                          And when the rest of my friends were at schools learning Fortran I was learning ALGOL, of which I remember absolutely nothing.
                          infiniteloopundefined 1 Reply Last reply Reply Quote 1
                          • infiniteloopundefined
                            infiniteloop @fcwilt
                            My first micro had a "keyboard" with two buttons and 2x8 DIP switches: one DIP to enter the address, the other to enter a data byte. The red button transferred a byte into one of the 256 bytes of RAM, the green button ran the program. As display, I had 8 LEDs.
                            • fcwiltundefined
                              fcwilt @infiniteloop
                              @infiniteloop said in Fine editor for working with Duet boards:
                              That must of been kind of tedious.
                              But it sounds something like an Intel microprocessor development system we had, which had a bunch of switches on the front. I remember we used them to enter the "boot loader" which then could read in the actual program from a paper tape reader.
                                Don't worry, the next machine I could work with was a IBM 5100 😉
                                • mikeabuilderundefined
                                  mikeabuilder
                                  I still have a prototype HP Intel 486 machine in my basement. It was really hot stuff at the time. My processor was double clocked - from 20Mhz to 40Mhz. That was hot stuff in it's time, about 30 years ago.
                                  • fcwiltundefined
                                    fcwilt @mikeabuilder
                                    @mikeabuilder said in Fine editor for working with Duet boards:
                                    Fun times for sure. I remember upgrading an IBM desktop from 4 to 6-8 Mhz - heady stuff.
                                    Who dreamed where we would be today with gigahertz clock speeds, gigabytes of memory and terabytes of solid state drives.
                                    • OwenDundefined
                                      OwenD
                                      @fcwilt
                                      Looks good 👍
                                      I have been using a free editor called
                                      RJ Texted.
                                      It also has FTP, but I haven't used it.
                                      I did a syntax file that allows auto completion and does mouse over help hints for existing files.
                                      https://forum.duet3d.com/topic/14637/reprap-g-code-syntax-now-part-of-rj-texted-text-editor/2?_=1654136072761
                                      The syntax file is no longer included as standard because it was changing too quickly.
                                      I see that you can do syntax highlighters in your editor as well, so it would be good for someone to do so.
                                      I looked at doing one for Notepad ++ but it was to clunky
                                      • fcwiltundefined
                                        fcwilt @OwenD
                                        @owend said in Fine editor for working with Duet boards:
                                        @fcwilt
                                        Looks good 👍
                                        RJ Texted.
                                        There are many syntax highlighters available, some created by the programs creator, some by end users.
                                        I haven't looked into how to make one but the Java one does give some highlighting.
                                        Is highlighting an "art form" or are there specific rules for each type of file?
                                        OwenDundefined 1 Reply Last reply Reply Quote 0
                                        • OwenDundefined
                                          OwenD @fcwilt
                                          I don't know if there are any rules per se.
                                          Mostly they use some sort of regex or keyword list to determine what to highlight.
                                          • Coffeeundefined
                                            Coffee @JuJuDelta
                                            Sneaking in a batch of cards to print KISS's logo a few dozen times to give to friends!
