    Fine editor for working with Duet boards
    Third-party software
    13
    50
    3.6k
    • fcwiltundefined
      fcwilt @Nightowl
      @nightowl999 said in Fine editor for working with Duet boards:
      @fcwilt
      That reminds me of similar software from Windows 3.1 days, but I can't remember the name! The interface is a bit like WinZip.
      Windows 3.1? You've been around a while.
      I don't think my use of it would justify the cost of Fine Editor, though - I'm happy (for now) to stick with the DWC as I have nowhere near as many as you! 🤣
      You might surprise yourself as you find all the new and interesting things you can do given the features they keep adding to the firmware.
      From time to time something like this that costs a bit (in this case $60) is mentioned and others express the concern about spending the money. But stop and think about the real cost of 3D printing. I don't want to think about how much money I have spent on filament. That $60 might only buy 2-3 spools of good quality filament. 😄
      What motivated me was a desire to use a more consistent naming scheme for files and variables.
      And to replace smallish blocks of code appearing in multiple places with a M98 call to a new file with that same block of code.
      Using a "real" editor made making all those changes a relatively painless process.
      Nightowlundefined 1 Reply Last reply Reply Quote 1
      • Nightowlundefined
        Nightowl @fcwilt
        @fcwilt said in Fine editor for working with Duet boards:
        How rude! 🤣 🤣
        Few things are more dangerous than taking the advice of someone who thinks he knows what he's doing.
        I'm still on my learning curve, so take everything I say with caution!
        RatRig 1075, Duet3 MB6HC, Sorotec SFM 1000 PV-ER milling motor, Hobbyist
        • fcwiltundefined
          fcwilt @Nightowl
          How rude! 🤣 🤣
          I use to use CP/M and actually did some productive work with it. Back then having a machine with 64K of memory was hot stuff.
          I also remember trying to use Windows 1.x and 2.x and how primitive they were.
          As I recall 3.x was the first with decent networking.
          We've come a long way.
          • Nightowlundefined
            Nightowl @fcwilt
            I use to use CP/M
            You've probably been around longer than me, then!
            JuJuDeltaundefined 1 Reply Last reply Reply Quote 1
            • JuJuDeltaundefined
              JuJuDelta @Nightowl
              Intel's Aedit running on MS-DOS was the best!
              8" floppies, MCS-51 Dev system on wheels the size of a fridge.
              And before that punched tape and cards!
              You didn't run programs, you submitted them as a batch file overnight, to then find out you made a typo!
              You "Younglings" are spoilt 🙂
              T3DP3D Kossel XL+, Duet2Wifi, PanelDue 7i, RRF V3.2, Fl3xdrive, SmartEffector, Berd Air annulus, Cura 4.x, PrusaSlicer, RPi WiFi Camera, Heated Chamber
              Nightowlundefined fcwiltundefined Coffeeundefined 3 Replies Last reply Reply Quote 3
              • Nightowlundefined
                Nightowl @JuJuDelta
                @jujudelta Haha!
                I do remember taking hours to programming a Sinclair ZX80 for it to beep, and finding I'd mis-typed something - or the magazine I'd tried to copy it from had an important piece of code cut with staples!
                • fcwiltundefined
                  fcwilt @JuJuDelta
                  @jujudelta said in Fine editor for working with Duet boards:
                  My first "programming" was on IBM accounting machines. You inserted a bunch of jumper wires from one hole to another, on a big "patch panel", to control what the machines did.
                  They couldn't do very much but they were large and loud!
                  And when the rest of my friends were at schools learning Fortran I was learning ALGOL, of which I remember absolutely nothing.
                  infiniteloopundefined 1 Reply Last reply Reply Quote 1
                  • infiniteloopundefined
                    infiniteloop @fcwilt
                    My first micro had a "keyboard" with two buttons and 2x8 DIP switches: one DIP to enter the address, the other to enter a data byte. The red button transferred a byte into one of the 256 bytes of RAM, the green button ran the program. As display, I had 8 LEDs.
                    • fcwiltundefined
                      fcwilt @infiniteloop
                      @infiniteloop said in Fine editor for working with Duet boards:
                      That must of been kind of tedious.
                      But it sounds something like an Intel microprocessor development system we had, which had a bunch of switches on the front. I remember we used them to enter the "boot loader" which then could read in the actual program from a paper tape reader.
                        Don't worry, the next machine I could work with was a IBM 5100 😉
                        • mikeabuilderundefined
                          mikeabuilder
                          I still have a prototype HP Intel 486 machine in my basement. It was really hot stuff at the time. My processor was double clocked - from 20Mhz to 40Mhz. That was hot stuff in it's time, about 30 years ago.
                          • fcwiltundefined
                            fcwilt @mikeabuilder
                            @mikeabuilder said in Fine editor for working with Duet boards:
                            Fun times for sure. I remember upgrading an IBM desktop from 4 to 6-8 Mhz - heady stuff.
                            Who dreamed where we would be today with gigahertz clock speeds, gigabytes of memory and terabytes of solid state drives.
                            • OwenDundefined
                              OwenD
                              @fcwilt
                              Looks good 👍
                              I have been using a free editor called
                              RJ Texted.
                              It also has FTP, but I haven't used it.
                              I did a syntax file that allows auto completion and does mouse over help hints for existing files.
                              https://forum.duet3d.com/topic/14637/reprap-g-code-syntax-now-part-of-rj-texted-text-editor/2?_=1654136072761
                              The syntax file is no longer included as standard because it was changing too quickly.
                              I see that you can do syntax highlighters in your editor as well, so it would be good for someone to do so.
                              I looked at doing one for Notepad ++ but it was to clunky
                              • fcwiltundefined
                                fcwilt @OwenD
                                @owend said in Fine editor for working with Duet boards:
                                @fcwilt
                                Looks good 👍
                                RJ Texted.
                                There are many syntax highlighters available, some created by the programs creator, some by end users.
                                I haven't looked into how to make one but the Java one does give some highlighting.
                                Is highlighting an "art form" or are there specific rules for each type of file?
                                OwenDundefined 1 Reply Last reply Reply Quote 0
                                • OwenDundefined
                                  OwenD @fcwilt
                                  I don't know if there are any rules per se.
                                  Mostly they use some sort of regex or keyword list to determine what to highlight.
                                  • Coffeeundefined
                                    Coffee @JuJuDelta
                                    Sneaking in a batch of cards to print KISS's logo a few dozen times to give to friends!
                                      deckingman @fcwilt
                                      My first was a Sinclair ZX81 (8 bit processor with 1K memory and cassette tape for "non-volatile" storage) circa 1981 that I bought in kit form. My second was a Texas Instruments TI-994A that I bought a couple of years later (so circa 1983) with a 16bit 3Mhz processor and separate VDP (Video Display Processor as they were called in those days).
                                      By 1983 I was 30 years old and these machines were big steps up from calculators, which in turn were big steps up from slide rules and books of log tables that was all we had in my school days.
                                      • cosmowaveundefined
                                        cosmowave
                                        Until 2009 i've built special machines with a Z80 controller board (2MHz, 2kB RAM).
                                        The complete controller board and all other electronic boards was soldered by hand... 💪
                                        I loved it to write programs in Z80 assembler. But the begin was hard!
                                        Mankati FSXT+, DeltaTowerV2, E3D MS/TC
                                        • fcwiltundefined
                                          fcwilt @deckingman
                                          @deckingman said in Fine editor for working with Duet boards:
                                          I still have mine.
                                          The white one is a typical one while the yellow one was for all things electronic.
                                          They are a bit more than 50 years old.
                                            Seeing as this has turned into an after school computer club thread, I'll share with you a "retro" computing device that you might find interesting.
                                            https://github.com/MiSTer-devel/Main_MiSTer/wiki
                                            It uses a FPGA board to do hardware emulation of old computers, consoles, arcade machines, etc. The list of supported devices is long. You can even emulate a PDP-1 if you like, and all the way up to a 486 class device capable of windows 95.
                                            https://github.com/MiSTer-devel/PDP1_MiSTer
                                            infiniteloopundefined fcwiltundefined 2 Replies Last reply Reply Quote 2
