1 thing stopping me now..
  • OK almost there.. 1 thing is still not right and I can't find answers searching… probably right in front of me.. LOL
    all axis move correctly, but Z end stop isn't registering.. it's the same mechanical one as X & Y which are both work fine. thinking it's something to do with "probe" but I don't have a probe and not sure how to shut off... 😞 just a guess though.
  • Please post your config.g here, we need that to know how you've set things up so far.
  • ; Configuration file for Duet WiFi (firmware version 1.17)
    ; generated by RepRapFirmware Configuration Tool on Mon Oct 16 2017 05:23:05 GMT-0400 (EDT)
    M111 S0 ; Debugging off
    G21 ; Work in millimetres
    M208 X230 Y210 Z200 S0 ; Set axis maxima
    M574 X1 Y1 Z1 S0 ; Define active low and unused microswitches
    M558 P1 X0 Y0 Z0 H5 F120 T6000 ; Set Z probe type to unmodulated, the axes for which it is used and the probe + travel speeds
    G31 P600 X0 Y0 Z2.5 ; Set Z probe trigger value, offset and trigger height
    M557 X15:215 Y15:195 S20 ; Define mesh grid
    M569 P0 S1 ; Drive 0 goes backwards
    M569 P2 S1 ; Drive 2 goes backwards
    M92 X80 Y80 Z400 E97 ; Set steps per mm
    M203 X6000 Y6000 Z180 E1200 ; Set maximum speeds (mm/min)
    M201 X500 Y20 Z250 E250 ; Set accelerations (mm/s^2)
    M906 X800 Y800 Z800 E800 I30 ; Set motor currents (mA) and motor idle factor in per cent
    M84 S30 ; Set idle timeout
    M143 S245 ; Set maximum heater temperature to 245C
    M563 P0 D0 H1 ; Define tool 0
    M550 PMax Micron ; Set machine name
    M552 S1 ; Enable network
    M587 **********; Configure access point. You can delete this line once connected
    M586 P0 S1 ; Enable HTTP
    M586 P1 S0 ; Disable FTP
    M586 P2 S0 ; Disable Telnet
    M106 P1 S1 I0 F500 H-1 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned off
    M106 P2 S1 I0 F500 H-1 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned off
  • just did a M119 and I get this if that helps? …. M119
    Endstops - X: at min stop, Y: at min stop, Z: not stopped, Z probe: not stopped
  • thinking it's in this section.. but no clue what to change/delete/ncomment…
  • If you're not using a Z-probe, then you shouldn't have the M558/G31/M557 lines (delete the whole line).
    Use M119 to test if the Z-endstop is wired properly - trigger it manually and check that it says "at min stop".
  • @dc42:
    Have you read https://duet3d.com/wiki/Configuring_RepRapFirmware_for_a_Cartesian_printer#Homing_Z ?
    no.. I hadn't ,… sweet!!! sooo much info and sooo little brain . 😉 . thanks . 🙂
    @elmoret:
    ya, thought that line(s) weren't needed but still WAY to new to this code/board and didn't want to make things worse (I have a habit of that 😉 )
  • No worries, we all start somewhere! Happy to help.
  • @dc42:
    That worked !!! thanks for pointing to that!! printed out the whole section, need to read through it throughly
  • OK new issue.. might be nothing? just did the PID auto tune thing.. after it came up with a warning..
    "warning, heater one appears to be over powered and a fire risk!! If left on at full power, it's temp is predicted to reach 757C"
    Umm ….ack?
    now the PID tune should prevent this correct?
    is there a way to lower the power coming out of the board? looked at the "hotend" settings but nothing says "hot end power", or voltage or something..
  • All a PID tune does is help the controller hold the desired temperature better, i.e. with less variation. Think of PID tuning as practicing walking on a tightrope - once your brain is trained (the PID gains are tuned), there's less wobbling around (temperature variation).
    A heater that powerful is a fire risk if the controller were to fail. I would guess you're using a 12v heater on 24v, or a 40w heater with a sock or other insulation?
  • @elmoret:
    nope, 12v system with 12v heater heater is stock MK8.. there is a sock on it I made.
    Ya I get the basis of the PID tune.. and got to say, it's WAY more stable than with marlin's.. getting like a 0.5º variation where marlin I was get +/-2º or more.
  • Sounds like a 40 watt heater with a sock. That is too much heat/too much insulation, if the Duet's FETs ever failed on, the hotend would reach ~700C, melt the heater block, and likely start a fire. Would recommend a 30w heater if you plan to use a sock.
    The PID tune won't prevent a fire as no matter what the gains are, it can't compensate for a hardware failure.
