    Seeking Duet user who moved from Simplify3D to Cura
    My Duet controlled machine
    574
    • fcwiltundefined
      fcwilt
      I have been using Simplify3D with my Duet powered printers for quite a while.
      Once I figured out good settings in S3D it has been working fine for me. I can slice a model and it prints without issues.
      Now I think it is time to move to Cura 5.
      I tried my best to take the PLA settings that worked in S3D and make the equivalent settings in Cura.
      But I cannot get the first layer adhesion in Cura that I get with S3D.
      What I get is wild nests of filament if I stop paying attention and cancel things at the first sign of problems
      So I was hoping to find someone who knew the "secret" to getting Cura to work.
      Thanks very much.
      Lo-Fiundefined taconiteundefined 2 Replies Last reply Reply Quote 0
      • Lo-Fiundefined
        Lo-Fi @fcwilt
        @fcwilt
        I've been using cura for quite a while now.
        My key things:
        Low speed ~30mm/s
        Large initial layer ~.2mm
        Optimise wall printing order is useful on parts that have many small holes on the bed.
        Small hole speed is also useful for getting the small hole walls to stick.
        Extrusion multiplier 110% Can be helpful too.
        I've found those things make far more difference than different nozzle or bed temps.
        That all being said, if you're getting good results from Simplify you ought to be able to replicate in Cura. I assume you're using the same speed, layer height etc?
        • A Former User?
          A Former User
          This post is deleted!
          fcwiltundefined 2 Replies Last reply Reply Quote 0
          • taconiteundefined
            taconite @fcwilt
            @fcwilt are you sure you habe filament diameter 1,75 Set in the settings? Default for cura is 2.85
            Custom ANET A8
            Custom Delta: D-PATCH (Delta Printer with Automatic Tool CHanging) https://forum.duet3d.com/topic/16082/d-patch?_=1596131234754
            All I do here is under this license: CC BY-NC-SA
            • fcwiltundefined
              fcwilt @A Former User
              @arnold_r_clark said in Seeking Duet user who moved from Simplify3D to Cura:
              1. Cura (just an abortion i couldn't get prints to stick to the bed, layer adhesion was terrible and what it did print was really inconsistent in quality
              And that is just what I am seeing, so far.
              I will take a look at IdeaMaker.
              Thanks.
              • fcwiltundefined
                fcwilt @Lo-Fi
                @lo-fi said in Seeking Duet user who moved from Simplify3D to Cura:
                @fcwilt
                My key things:
                I will need to look at those - I didn't change them from the defaults.
                Thanks.
                • fcwiltundefined
                  fcwilt @taconite
                  @taconite said in Seeking Duet user who moved from Simplify3D to Cura:
                  I will double check that.
                  Thanks.
                  • fcwiltundefined
                    @arnold_r_clark
                    I installed and tried ideaMaker.
                    I went through it looking for the settings that I made in S3D and think I found them all.
                    In any case the first test print came out just fine, the same print Cura failed at repeatedly due to terrible first layer adhesion.
                    It's curious that Cura is so bad in the regard.
                    Thanks for the suggestion.
                    • A Former User?
                      A Former User @fcwilt
