    Rapido UHF Hotend Thermistor value
    • selva_tviundefined
      selva_tvi
      Hi all,
      We are using Duet 3 Mini 5+ board.
      And using Rapido UHF hotend. Their thermistor is 104NT-4-R025H42G with a heating power of 115W.
      I am using a B value of 4138. And did the PID tuning. It is fine now.
      Still wondering, is there another B value should I use?
      Thanks
        @selva_tvi said in Rapido UHF Hotend Thermistor value:
        104NT-4-R025H42G
        Using just a B value and no C value won't give you accurate readings at high temperatures. I suggest you take three resistance-temperature values from the table at https://static.rapidonline.com/pdf/61187_v2.pdf (e.g. 25C, 130C and 250C) and plug them into the calculator in the configuration tool, to calculate appropriate B and C values.
          selva_tvi
          @dc42 Thanks.
          Is it this configurator?
          https://configtool.reprapfirmware.org/Start
          If not mistaken, where can i get the calculator?
            jay_s_uk @selva_tvi
            @selva_tvi its on the heaters page. click on the B or C value and then from the drop down box select custom. you can then fill in some values
            selva_tviundefined 1 Reply Last reply Reply Quote 0
              selva_tvi @jay_s_uk
              Hidden calculator. Thanks
