    asking again, Duet 3 6hc running Klipper?
    Using Duet Controllers
    klipper duet3 duet36hc
    12
    28
    3.4k
    • A Former User?
      A Former User @oliof
      This post is deleted!
      oliofundefined 1 Reply Last reply Reply Quote -2
      • oliofundefined
        oliof @A Former User
        Trust me, your post does reflect badly on this community.
        A Former User? 1 Reply Last reply Reply Quote 2
        • A Former User?
          oliofundefined T3P3Tonyundefined 2 Replies Last reply Reply Quote -3
          • oliofundefined
            @Herve_Smith And a good day to you you, too!
            • T3P3Tonyundefined
              T3P3Tony administrators @A Former User
              @Herve_Smith the issue with your post is not that you believe the problems with klipper's can bus usage are due to the implementation, rather than the underlying architecture. The issue is the personal attacks: "raving idiot" , along with the overly aggressive tone.
              As @oliof has already pointed out, there is no place on this forum for this behaviour. Please use a constructive and friendly tone, even when you disagree with an opinion.
              www.duet3d.com
              • Wulfstaundefined
                Wulfsta @oliof
                @oliof I posted a script to flash 1LC boards using OpenOCD and a Pi elsewhere on the forum.
                oliofundefined 1 Reply Last reply Reply Quote 1
                • oliofundefined
                  oliof @Wulfsta
                  @Wulfsta this one I presume https://forum.duet3d.com/topic/29857/raspberry-pi-4-to-toolboard-1lc-with-openocd/14?_=1682879698520
                  Wulfstaundefined 1 Reply Last reply Reply Quote 1
                  • Wulfstaundefined
                    Wulfsta @oliof
                    @oliof yeah, that’s it. Huge pain to figure that out. I’ll add docs to klipper eventually, but it’s not my priority at the moment. Meanwhile it should be easy enough to figure out by looking at the schematics.
