    Unable to get on DWC
    Firmware installation
    347
    • darbyad85undefined
      darbyad85
      I have been happily connected for 24 hours and not i cannot get on the Duet Web Control
      I am connected to WIFI and can see the screen in the background but i am getting a blue screen saying connecting and at the bottom the following message
      Failed to connect - incompatible fireware
      I just wanted to check it would be the Duet that needs firmware updating? I am running version 2.03 currently
      What i dont understand is why did it work yesterday and not today?
        jay_s_uk @darbyad85
        @darbyad85 did you update anything yesterday?
          darbyad85
          @jay_s_uk I've updated the firmware and it doesn't seem to have solved the problem. M552 61 is confirming I am connected and the right IP address for DWC but all I get is a blue bar saying 'Connecting...' with no connection
            jay_s_uk @darbyad85
            @darbyad85 did you update DWC at the same time? thats probably the issue
              darbyad85
              I updated the wifi and rap/rep at the same time, is there also an update for the DWC
              I was on version 2.03 but used the Duet 2 and 3 firmware 3.0 as advised - is there something else i have missed?
              Thanks
                jay_s_uk @darbyad85
                @darbyad85 do you know what firmware version you ended up with? Was it RRF 3.0 or 3.4.1?
                  darbyad85
                  I have 3.0 i didnt upgrade to 3.4.1
                  I have found the DWC zip file that is part of 3.0 - can i just install the same way i did to get to version 3.0 or do i delete and install all together?
                    jay_s_uk @darbyad85
                    @darbyad85 you can just delete the contents of the www folder and replace it with the contents of the dwc zip file
                      darbyad85
                      thank you, do I need to perform M997 S0?
                        jay_s_uk @darbyad85
                        @darbyad85 no, DWC files are just held on the SD card. that should get you up and running
                          darbyad85
                          thanks so much - I am indeed up and running!
                            Now that you're at 3.0 you should probably update to 3.4.1
                            3.0 was a very early release, much has changed.
                            Updating now is as simple as uploading a single zip file to the system tab in DWC. Do not decompress it first.
                            https://github.com/Duet3D/RepRapFirmware/releases/download/3.4.1/Duet2and3Firmware-3.4.1.zip
                            And if you're coming from 2.03 you should probably generate a new config file set.
                            https://configtool.reprapfirmware.org/Start
