    HELP! Can't log in to both machinesWIFI passwords!?
    58
    3.5k
    • FuseDeepundefined
      FuseDeep
      Bit of an emergency.
      My laptop completely crapped out and now the wifi is asking me for passwords to both my 3dprinters...I don't have them!
      How do I sort this ASAP please?
      Where do I find the password?
      Am in a hurry to print a piece for a show so this is very bad timing!
      Rich
      Visionaryundefined 1 Reply Last reply Reply Quote 0
      • Visionaryundefined
        Visionary @FuseDeep
        @fusedeep
        In my Duet 2 Wifi I can see/change my password in folder sys/config.g
        3D-printer part collector || https://grabcad.com/eetu-4/models
        FuseDeepundefined 1 Reply Last reply Reply Quote 0
        • FuseDeepundefined
          FuseDeep @Visionary
          @visionary I currently can't connect at all.
          Last time YAT failed and putty is playing up!
          I have a copy of my congig.g file open and there is no password line!
            Visionary @FuseDeep
            @fusedeep
            https://docs.duet3d.com/User_manual/Troubleshooting/WiFi_troubleshooting
            From Duet documentation:
            If you are completely unable to connect, you can remove the SD card and edit the config.g files so that the network setup commands are run at startup
            FuseDeepundefined 1 Reply Last reply Reply Quote 1
            • FuseDeepundefined
              FuseDeep @Visionary
              @visionary I have opened the SD card and found config.g in the folder and edited in notepad...but how do i save as a G file?
                Visionary @FuseDeep
                @fusedeep
                Open it directly by clicking the file that is already in g-filetype and choose some text editor (that your PC asks) and use regular save to save it with the filetype the file already has.
                • FuseDeepundefined
                  FuseDeep @Visionary
                  @visionary that seems to be a dot g filename?
                  Am not getting that option.
                  • FuseDeepundefined
                    FuseDeep
                    Bit of a disaster and I have one more piece to print!
                    AFAIK I have never had passwords on fusedeep or my point6 machine/M2
                    After laptop trouble, the laptop started to ask for passwords, I don't have any.
                    I have directly edited the sd card to add a password, but this is now simply not working.
                    Currently all my machines are out of action!'
                    I knew relying on wifi was a bad idea...
                    What the heck has happened?
                    infiniteloopundefined 1 Reply Last reply Reply Quote 0
                      Visionary @FuseDeep
                      @fusedeep
                      Try opening some text editor and open the file from it. Then save the file after changes.
                      • infiniteloopundefined
                        infiniteloop @FuseDeep
                        @fusedeep said in HELP! Can't log in to both machinesWIFI passwords!?:
                        Do you get access to your WiFi at all, or has your laptop "forgotten" its own WiFi password?
                        FuseDeepundefined 4 Replies Last reply Reply Quote 0
                        • FuseDeepundefined
                          FuseDeep @infiniteloop
                          @infiniteloop
                          I managed to get my phone hotspot sorted by finding the phone key.
                          Neither of my duets even have a password. I am panicking/annoyed. I have wasted 2 hrs on this today and have a show to be ready for...
                          The laptop never usually asks for anyhting and just connects. I have no passwords set up in the config file. What is duet netwrok security key?
                          • FuseDeepundefined
                            @infiniteloop wifi uttely disappeared on laptop, no icons or anything. I deleted wifi devices and restarted machine. now it is asking for keys.
                            • FuseDeepundefined
                              @infiniteloop I use my android phone hotspot in studio, this is now working fine. but I have no security keys, afaik, for either duet set up!
                              Stephen6309undefined 1 Reply Last reply Reply Quote 0
                              • FuseDeepundefined
                                @infiniteloop I use adhoc wifi to duets but the laptop seems to be trying to get the key for a central router.'
                                There isn't one!
                                • Stephen6309undefined
                                  Stephen6309 @FuseDeep
                                  @fusedeep Can you go to a web page, like www.google.com? Are you sure the laptop is logged in to the WiFi?
                                  • FuseDeepundefined
                                    FuseDeep @Stephen6309
                                    @stephen6309 positive. am using my phone hotspot now to respond and internet works. but for adhoc to duets it wants a network key. there isn't one...
                                      @fusedeep This may help: https://docs.duet3d.com/en/User_manual/Machine_configuration/Networking
                                        Normally: none. @Visionary told you how to set/change the PW in config.g on your SD card. He's right - I just advise you to put the following lines into your config (if they are missing):
                                        M551 P"reprap"
                                        M552 S1						; Turn network on
                                        Setting the password (with M551) to "reprap" tells the Duet not to ask for a password at all.
                                        If you've done this, you can be sure that any requests for a password originate from another source - router or laptop.
                                        • FuseDeepundefined
                                          @stephen6309 I don't think it is this.
                                          It was all fine, for months until my laptop wifi crashed out.
                                          Now it is asking for a network key for my duets. they don't afaik have one!
                                          It is a genuine pita.
                                          • FuseDeepundefined
                                            @infiniteloop I did exactly this and it made no difference. I put a new PASSWORD via and sd card reader and notepad edit and it would not connect.
                                            The laptop is asking for a SECURITY NETWORK KEY
                                            This is incorrect,
                                            This is a laptop /adhoc issue and not duet as such.
                                            Though my android phone won;t connect either, but i also never tried that before.
