power cut
Hello print friends.
But there happens a little unexpected problem a power cut and my printer gave me an error when I wanted to restart the print any idea please? -
@sgk My bet is you have a
G29 S1
early on in your config.g. If this is a RatRig V-Core machine, that was an error in their example config. Either remove that line or -- if it is the V-Core config -- change it toG21
@oliof hello tank you for help look my config i no have the g29config.txt
@sgk you are loading config-override.g at the end of config.g -- please share that as well. It would probably be fine to remove the M500 to avoid rewriting config-override.g everytime the machine boots.
@oliof like that config.txt
@sgk I see now this happens after you issue M916 ... you may need to look at
/sys/resurrect.g
and/sys/resurrect-prologue.g
The message is a warning, and since you may not be able to probe Z when doing power loss recovery, since the bed has a (partial) print which may interfere with probing Z
this my resurrect-prologueresurrect-prologue.g
@sgk so yeah, the warning is because you cannot probe Z since a print is on the bed. I think you got to live with it after power failure unless you have a fail-safe way to probe Z0 with a full bed, which usually is not the case.
@oliof ok thank you for or help
