    Did RRF stop writing print time to gcode files?
    • oliofundefined
      oliof
      I am trying to gauge print time estimates with actual print time but I can't seem to get the actual print time for completed jobs anymore. I dimly remember that was written to the end of a gcode file in the past. Am I hallucinating, has this feature been removed? My usual code spelunking has proven inefficient this time.
        dc42 administrators @oliof
        @oliof actual print time has never been written to GCode files. Simulated print time is.
        oliofundefined jay_s_ukundefined 2 Replies Last reply Reply Quote 0
        • oliofundefined
          oliof @dc42
          @dc42 ok, hallucination then (-:
            jay_s_uk @dc42
            @dc42 what's stopping actual being written at the end of a print? Could this make the wishlist?
            dc42undefined 1 Reply Last reply Reply Quote 2
            • OwenDundefined
              OwenD
              Not sure what format is expected, but you can easily enough append the info to the file by putting something like this is stop.g
              Edited for better readability
              if (job.lastFileName != null)
              	var numHours = floor({job.lastDuration}/3600)
              	var numMins = floor(({job.lastDuration}-var.numHours*3600)/60)
              	var numSecs = mod({job.lastDuration},60)
              	var thisString = ";Print time = " ^ var.numHours ^ "hrs " ^ var.numMins ^ "min " ^ var.numSecs ^ "secs"
              	echo >>{job.lastFileName} ""
              	echo >>{job.lastFileName} ";Last printed:", state.time
              	echo >>{job.lastFileName} var.thisString
              note as written it will append the info if stop.g was run after a file was cancelled or aborted.
              I have another post about that as it seems to be a bug.
                dc42 administrators @jay_s_uk
                @jay_s_uk yes we could write last printed time to the end of the file, although if you adjust the printing speed during the print as I often do then the value is less useful than the simulated time.
                jay_s_ukundefined 1 Reply Last reply Reply Quote 2
                  jay_s_uk @dc42
                  @dc42 I personally don't. It would be appreciated if you could. Thanks
