    duet3hc6 resets on tool change
    • akayoshi
      akayoshi last edited by
      Hi all,
      I've built a custom idex cartesian with a Duet3HC6 and Duet 3 Expansion 3HC running two e3d hemeras.
      The issue I've been having is that Duet 3 mainboard will reset after a tool change. The board resets consistently at the same position in the print. I use Cura as my slicer. I've was running 3.2.2 for a long time, and hoped the upgrade to 3.4.1 would fix the error. Unfortunately, that hasn't been the case. I've attached a copy of my gcode as well. In this model, the board resets at layer 26 or 27 when the tool 0 is set to print.
      config.g
      ; generated by RepRapFirmware Configuration Tool v3.2.3 on Wed Mar 31 2021 21:23:47 GMT+1100 (Australian Eastern Daylight Time)
      M550 P"duet"                                     ; set printer name
      M552 P0.0.0.0 S1                                   ; enable network and acquire dynamic address via DHCP
      M569 P0.0 S0                                       ; x physical drive 0.0 goes forwards: idex 1
      M569 P0.1 S1                                       ; u physical drive 0.1 goes forward: idex 2
      M569 P0.2 S0                                       ; y physical drive 0.2 goes backwards: y axis
      M569 P0.3 S0                                       ; Z axis 1
      M569 P0.4 S0                                       ;z axis 2
      M569 P0.5 S1                                       ;Extruder 1
      M569 P1.0 S1                                       ; extruder 2
      M584 X0.0 Y0.2  U0.1 Z0.3:0.4 E0.5:1.0
      M671 X-120:440 Y185:185 p40
      ;M208 X-100:420 Y0:380
      M208 x-100 u0 y0 z0 s1 ; set axis minima
      m208 x420 u524 y380 z400 s0 ; higher u moves extruder 2 to right
      M350 X16 U16 Y16 Z16 E16 i1                             ; configure microstepping with interpolation
      M92 X80.00 U80 Y80.00 Z400.00 E398.58:394.2                  ; set steps per mm
      M566 X700.00 U700 Y700.00 Z60.00 E120.00                ; set maximum instantaneous speed changes (mm/min)
      M203 X12000.00 U12000 Y12000.00 Z180.00 E1200.00          ; set maximum speeds (mm/min)
      M201 X500.00 U500 Y500.00 Z20.00 E250.00                ; set accelerations (mm/s^2)
      M906 X800 u800 Y1500 Z700 E800:800 I30       ; set motor currents (mA) and motor idle factor in per cent
      M911 S21.0 R23.0 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; if voltage drops <21v
      M574 X1 S1 P"io2.in"                               ; configure active-high endstop for low end on X via pin io4.in
      M574 Y1 S1 P"io3.in"                               ; configure active-high endstop for high end on Y via pin io3.in
      M574 U2 S1 P"!io5.in"
      M915 U R0 F0
      M574 Z1 S2                                         ; configure Z-probe endstop for low end on Z
      M950 S0 C"io7.out"                                 ; create servo pin 0 for BLTouch
      M558 P9 C"io7.in" H5 F120 T6000                   ; set Z probe type to bltouch and the dive height + speeds;G31 P500 X-41 Y5 Z2.5                              ; set Z probe trigger value, offset and trigger height
      ;G31 P500 X32.5, Y-42 z.66 ; 6/9/21
      G31 P500 X32.5, Y-42 z.8
      M557 X60:420 Y0:330 S50                           ; define mesh grid
      M280 P0 S90
      ;Bed
      M308 S0 P"temp0" Y"thermistor" T100000 B4138       ; configure sensor 0 as thermistor on pin temp0 - Heated BED
      M950 H0 C"out1" T0                                 ; create bed heater output on out2 and map it to sensor 0
      M307 H0 B0 S1.00                                   ; disable bang-bang mode for the bed heater and set PWM limit
      M143 H0 S120; set temperature limit for heater 0 to 120C
      ;Extruder 1
      M308 S1 P"temp1" Y"thermistor" T165000 B4725 c7.06e-8 R2200 ; configure sensor 1 as thermistor on pin temp1 - Extruder 1
      M950 H1 C"out2" T1                                 ; create nozzle heater output on out1 and map it to sensor 1
      ;Extruder 2
      M308 S2 P"temp2" Y"thermistor" T100000 B4725 c7.06e-8 ; configure sensor 1 as thermistor on pin temp1 - Extruder 1
      M950 H2 C"out3" T2                                 ; create nozzle heater output on out1 and map it to sensor 1
      M307 H2 B0 S1.00                                   ; disable bang-bang mode for heater  and set PWM limit
      M143 H2 S280                                       ; set temperature limit for heater 1 to 280C
      ; Extruder 1 - part fan
      M950 F0 C"out7" Q500                               ; create fan 0 on pin out7 and set its frequency
      m106 p0 s0 ; set fan 0 value. Thermostatic control is turned on
      ; Extruder 2 - hot end fan
      M950 F1 c"out8" Q500
      m106 p1 s1 h2										; Extruder 2 - part fan
      ;Part fan
      M950 F2 c"out9" q500								; create fan 1 on pin out8 and set its frequency
      M106 P2 S0
      ;''' Tool configuration section of config.g'''
      ;''' Create a tool that uses the low end (X) carriage'''
      M563 P0 S"Extuder A" D0 H1 F0            ; tool 0 uses extruder 0, heater 1 and fan 0
      G10 P0 X0 Y0 Z0 S0 R0       ; set tool 0 offsets and temperatures
      M591 P1 C"io4.in" S1 D0 ; filament monitor connected to E0 endstop
      M591 P2 C"io1.in" S1 D1
      ;''' Create a tool that uses the high end (U) carriage'''
      M563 P1 S"Extruder B" D1 H2 X3 F3         ; tool 1 uses extruder 1, heater 2, fan 2, and maps X to U
      G10 P1 Y2.5 U0 Z7.7 S0 R0 ;adjusts extrude 2 offset.  larger number, the closer to bed, larger y moves to front
      ;M671 X80:460:460:80 Y300:300:-35:-35 P0.5
      M501                                               ; load saved parameters from non-volatile memory
      M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z2.7 E-5 F1000" ; set voltage thresholds and actions to run on power loss
      ;M207 S2.0 F2400 Z.6  5/9/21
      M207 P0 S2.0 F7200 Z0
      M929 s1
      tfree0.g
      M83 ; relative extruder movement
      G1 E-2 F3600 ; retract 2mm
      M106 S0           ; turn off our print cooling fan
      G91 ; relative axis movement
      G1 Z10 F500 ; up 3mm
      G90 ; absolute axis movement
      G1 S2 X-100 F6000 ; park the X carriage at -48mm
      m561
      m564 s0
      tfree1.g
      ; tfree1.g
      ; called when tool 1 is freed
      G1 S2 U511 F6000 ; park the U carriage at +248mm
      tpost0.g
      M106 R2           ; restore print cooling fan speed
      M116 P0 ; wait for tool 0 heaters to reach operating temperature
      G1 E2 F3600 ; extrude 2mm
      tpost1.g
      M116 P1 ; wait for tool 1 heaters to reach operating temperature
      M122
      19/06/2022, 14:55:39	M122
      RepRapFirmware for Duet 3 MB6HC version 3.4.1 (2022-06-01 21:09:01) running on Duet 3 MB6HC v1.01 or later (standalone mode)
      Board ID: 08DJM-956L2-G43S8-6J1D6-3S46T-KU2QF
      Used output buffers: 3 of 40 (38 max)
      Static ram: 151000
      Dynamic ram: 97424 of which 64 recycled
      Never used RAM 102184, free system stack 200 words
      Tasks: NETWORK(ready,26.7%,227) ETHERNET(notifyWait,0.2%,168) HEAT(notifyWait,0.0%,321) Move(notifyWait,0.0%,352) CanReceiv(notifyWait,0.0%,772) CanSender(notifyWait,0.0%,374) CanClock(delaying,0.0%,339) TMC(notifyWait,7.9%,92) MAIN(running,65.2%,1101) IDLE(ready,0.0%,30), total 100.0%
      Owned mutexes:
      Last reset 00:05:52 ago, cause: power up
      Last software reset at 2022-06-18 22:27, reason: User, GCodes spinning, available RAM 98688, slot 1
      Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0044a000 BFAR 0x00000000 SP 0x00000000 Task MAIN Freestk 0 n/a
      Error status: 0x00
      Step timer max interval 132
      MCU temperature: min 15.0, current 31.4, max 31.6
      Supply voltage: min 23.8, current 23.8, max 23.9, under voltage events: 0, over voltage events: 0, power good: yes
      12V rail voltage: min 12.0, current 12.1, max 12.1, under voltage events: 0
      Events: 0 queued, 0 completed
      Driver 0: standstill, SG min 0, mspos 8, reads 63665, writes 14 timeouts 0
      Driver 1: standstill, SG min 0, mspos 8, reads 63664, writes 15 timeouts 0
      Driver 2: standstill, SG min 0, mspos 8, reads 63665, writes 14 timeouts 0
      Driver 3: standstill, SG min 0, mspos 8, reads 63665, writes 14 timeouts 0
      Driver 4: standstill, SG min 0, mspos 8, reads 63665, writes 14 timeouts 0
      Driver 5: standstill, SG min 0, mspos 8, reads 63666, writes 14 timeouts 0
      Date/time: 2022-06-19 14:56:01
      Slowest loop: 6.83ms; fastest: 0.05ms
      === Storage ===
      Free file entries: 9
      SD card 0 detected, interface speed: 25.0MBytes/sec
      SD card longest read time 1.3ms, write time 1.9ms, max retries 0
      DMs created 125, segments created 0, maxWait 0ms, bed compensation in use: none, comp offset 0.000
      === MainDDARing ===
      === AuxDDARing ===
      Bed heaters 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0
      Segments left: 0
      Movement lock held by null
      HTTP is idle in state(s) 0
      Telnet is idle in state(s) 0
      File is idle in state(s) 0
      USB is idle in state(s) 0
      Aux is idle in state(s) 0
      Trigger is idle in state(s) 0
      Queue is idle in state(s) 0
      LCD is idle in state(s) 0
      SBC is idle in state(s) 0
      Daemon is idle in state(s) 0
      Aux2 is idle in state(s) 0
      Code queue is empty
      === Filament sensors ===
      Extruder 0 sensor: ok
      === CAN ===
      Messages queued 3178, received 2826, lost 0, boc 0
      Longest wait 1ms for reply type 6042, peak Tx sync delay 6, free buffers 50 (min 49), ts 1762/1761/0
      Tx timeouts 0,0,0,0,0,0
      === Network ===
      Slowest loop: 27.33ms; fastest: 0.02ms
      Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions Telnet(0), 0 sessions
      HTTP sessions: 3 of 8
      - Ethernet -
      State: active
      Error counts: 0 0 1 0 0
      Socket states: 5 2 2 2 2 0 0 0
      M98 P"config.g"
      19/06/2022, 14:56:55	HTTP is enabled on port 80
      FTP is disabled
      TELNET is disabled
      Error: Filament monitor port must be on same board as extruder driver
      Warning: Heater 1 predicted maximum temperature at full power is 536°C
      Warning: Heater 2 predicted maximum temperature at full power is 512°C
      19/06/2022, 14:56:54	M98 P"config.g"
      FTP is disabled
      TELNET is disabled
      [microsope stand5.gcode](/assets/uploads/files/1655616088893-microsope-stand5.gcode) code_text
        Phaedrux Moderator @akayoshi last edited by
        @akayoshi said in duet3hc6 resets on tool change:
        Is this M122 gathered immediately after the reset? It seems to think that it was a power reset, so check that you don't have a short or other problem with the PSU.
        akayoshi 1 Reply Last reply Reply Quote 0
        • akayoshi
          akayoshi @Phaedrux last edited by
          @phaedrux the m122 command was issued the next day. I can’t recall if I had power cycled the printer with the power switch…
          However I don’t think it is an issue with the power supply as the board resets at the same position in the print.
          Any other ideas?
          akayoshi fcwilt Phaedrux 3 Replies Last reply Reply Quote 0
          • akayoshi
            akayoshi @akayoshi last edited by
            I had the same issue in august 2021, but I didn’t really persist with troubleshooting the issue.
            https://forum.duet3d.com/topic/24788/duet-3-idex-resets-at-consistent-position?_=1655821071814
            • fcwilt
              fcwilt @akayoshi last edited by
              @akayoshi
              Have you corrected the issue with the wiring of the filament monitor?
              Aside from that I would suspect a wiring issue leading to a short at certain positions of the tool.
                Any other ideas?
                Well without an M122 capture directly after the fault without a power cycle in between we don't know what the issue is. The current M122 you've shown only points to power being cycled.
                Now if it is a power fault getting triggered at that point I would say look at the wiring. Is there something about the head position at that point that causes a short?
                Are your stepper motors and hotend metal work grounded?
                • oliof
                  oliof last edited by
                  does the board also fault when you simulate the print?
                  <>Creality CR-20 IDEX Duet3 mini 5+<>RatRig V-Minion SKR RRF 1.1<>
