My config.g was reset
My config.g file is suddenly empty? What happened? I just reset my printer, and now all my settings are gone.
; Configuration file for Duet 3 (firmware version 3.3) ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool v3.3.10 on Wed Jun 15 2022 16:15:51 GMT+0200 (Central European Summer Time) ; General preferences M575 P1 S1 B57600 ; enable support for PanelDue G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"Duet 3" ; set printer name M665 R272 L503 B173 H355 ; Set delta radius, diagonal rod length, printable radius and homed height M666 X0.618 Y-0.625 Z0.007 A0.08 B0.05 ; put your endstop adjustments here, or let auto calibration find them M579 X1.0 Y1.0 Z1.0 ; XYZ scaling factor ; Drives M569 P0.0 S1 ; physical drive 0.0 goes forwards X M569 P0.1 S1 This is all that is left
@fcwilt I copied everything from there, to config.g, but now the same happend to the bak file. Copied everything to a txt file for now.
Did you edit and save the config.g file before the reset?
Firmware version and board type?
@phaedrux I save every time I make an edit. Duet 3 6HC, 3.4.1
@velvia The config.g file disappearing on save is an annoying and infrequent bug that we have been trying to chase down for a while, though have made progress on recently. See @chrishamm's post in this thread for an updated version of the firmware that may fix this issue: https://forum.duet3d.com/post/285788
