    Tool Fan and Primary Blower Fan Linked?
    • tfjieldundefined
      tfjield
      So with Cura I start my first layer with no blower fan, and then increase the fan to 100% at 20 mm. It increases gradually. Today I noticed that DWC is showing that my tool fan is doing the same:
      If I try to change one ,the other changes, too.
      Here's the relevant section of my config.g:
      ; Fans______________________________________________________________
      M950 F0 C"fan0" Q500                            ; create fan 0 on pin fan0 and set its frequency
      M106 P0 S0 H-1 C"Primary blower fan"		; set fan 0 value. Thermostatic control is turned on
      M950 F1 C"fan1" Q500                            ; create fan 1 on pin fan1 and set its frequency
      M106 P1 S0 H-1 C"Secondary blower fan"		; set fan 1 value. Thermostatic control is turned on
      M950 F2 C"duex.fan7" Q500                   	; create LED on pin fan2 and set its frequency
      M106 P2 S0 H-1 C"LED"                		; Disable fan channel for LED
      M106 P2 S255					; LED on by default
      M950 F3 C"duex.fan5" Q500     			; create fan 3 on pin fan1 and set its frequency
      M106 P3 S255 H0 T45              		; set fan 3 value. Thermostatic control is turned on
      M950 F4 C"duex.fan6" Q500     			; create fan 4 on pin fan1 and set its frequency
      M106 P4 S255 H1 T45              		; set fan 4 value. Thermostatic control is turned on
      Fan 3 is my tool head fan, and it's thermostatically controlled.
      In the files I'm printing, the blower fan speed is increased like this:
      M106 S13.4
      with slowly increasing values.
      Any idea what's going on?
      • fcwiltundefined
        fcwilt @tfjield
        @tfjield
        The DWC automatically displays the part cooling fan for the active tool.
        So you can hide your "Primary blower fan" and just use the fan the DWC displays.
        tfjieldundefined 1 Reply Last reply Reply Quote 1
        • tfjieldundefined
          tfjield @fcwilt
          @fcwilt I'm sorry, I'm not sure I understand. Are you saying that the "tool fan" isn't actually the fan blowing at my heat break, but it's just another name for the primary blower fan?
            jay_s_uk @tfjield
            @tfjield yes. They're the same thing. The tool fan is the part cooling fan of the active tool. Nothing to do with the hotend fan
            • tfjieldundefined
              tfjield @jay_s_uk
              @jay_s_uk Ah, thank you! That makes sense now that I think about it... I never named the hotend fan "Tool Fan." It just seemed like the tool fan! lol
              And thanks @fcwilt!
