    Non-PWM hotend fan always on with thermostatic control
    • Velviaundefined
      Velvia
      Fan / heater config
      M308 S0 P"temp1" Y"thermistor" T118000 B3950
      M950 H0 C"out1" T0                                 ; create bed heater output on out1 and map it to sensor 0
      M307 H0 B0 S1.00                                   ; disable bang-bang mode for the bed heater and set PWM limit
      M308 S1 P"temp0" Y"pt1000"                         ; configure sensor 1 as PT1000 on pin temp0
      M950 H1 C"out2" T1                                 ; create nozzle heater output on out2 and map it to sensor 1
      M307 H1 B1 S1.00                                   ; disable bang-bang mode for heater  and set PWM limit
      M143 H1 S450                                       ; set temperature limit for heater 1 to 450C
      M950 F0 C"out5"                                    ; create fan 0 on pin out5 and set its frequency
      M106 P0 S0 H1 T60                                  ; set fan 0 value. Thermostatic control is turned on
      M950 F1 C"out6" Q100                               ; create fan 1 on pin out6 and set its frequency
      M106 P1 S0.5 H-1                                   ; set fan 1 value. Thermostatic control is turned off
      T0
      M563 P0 S"DragonHF" D0 H1 F0                       ; define tool 0
      The hotend cooling fan is always on, even when below 60C.
      M122
      M122
      RepRapFirmware for Duet 3 MB6HC version 3.4.1 (2022-06-01 21:09:01) running on Duet 3 MB6HC v1.01 or later (SBC mode)
      Board ID: 08DJM-9P63L-DJ3S0-7JKF0-3S86T-TAJR8
      Used output buffers: 1 of 40 (12 max)
      Static ram: 151000
      Dynamic ram: 64296 of which 96 recycled
      Never used RAM 135280, free system stack 216 words
      Tasks: SBC(resourceWait:,0.5%,484) HEAT(notifyWait,0.0%,321) Move(notifyWait,0.0%,352) CanReceiv(notifyWait,0.0%,944) CanSender(notifyWait,0.0%,374) CanClock(delaying,0.0%,333) TMC(notifyWait,7.7%,92) MAIN(running,91.1%,1231) IDLE(ready,0.6%,30), total 100.0%
      Owned mutexes: HTTP(MAIN)
      Last reset 00:03:01 ago, cause: software
      Last software reset at 2022-06-28 12:49, reason: User, GCodes spinning, available RAM 135280, slot 1
      Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0x00000000 SP 0x00000000 Task SBC Freestk 0 n/a
      Error status: 0x00
      Aux0 errors 0,0,0
      Step timer max interval 135
      MCU temperature: min 34.9, current 35.2, max 35.6
      Supply voltage: min 23.9, current 24.0, max 24.0, under voltage events: 0, over voltage events: 0, power good: yes
      12V rail voltage: min 12.2, current 12.2, max 12.3, under voltage events: 0
      Events: 0 queued, 0 completed
      Driver 0: standstill, SG min 0, mspos 590, reads 31022, writes 14 timeouts 0
      Driver 1: standstill, SG min 0, mspos 706, reads 31022, writes 14 timeouts 0
      Driver 2: standstill, SG min 0, mspos 618, reads 31022, writes 14 timeouts 0
      Driver 3: standstill, SG min 0, mspos 8, reads 31022, writes 14 timeouts 0
      Driver 4: standstill, SG min 0, mspos 8, reads 31025, writes 11 timeouts 0
      Driver 5: standstill, SG min 0, mspos 8, reads 31026, writes 11 timeouts 0
      Date/time: 2022-06-28 12:52:53
      Slowest loop: 1.21ms; fastest: 0.05ms
      === Storage ===
      Free file entries: 10
      DMs created 125, segments created 0, maxWait 0ms, bed compensation in use: none, comp offset 0.000
      === MainDDARing ===
      === AuxDDARing ===
      Bed heaters 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0
      Segments left: 0
      Movement lock held by null
      Telnet is idle in state(s) 0
      File is idle in state(s) 0
      USB is idle in state(s) 0
      Aux is idle in state(s) 0
      Queue is idle in state(s) 0
      LCD is idle in state(s) 0
      SBC is idle in state(s) 0
      Daemon is idle in state(s) 0
      Aux2 is idle in state(s) 0
      Code queue is empty
      === CAN ===
      Messages queued 1625, received 0, lost 0, boc 0
      Longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 50 (min 50), ts 908/0/0
      Tx timeouts 0,0,907,0,0,716 last cancelled message type 4514 dest 127
      === SBC interface ===
      Transfer state: 5, failed transfers: 0, checksum errors: 0
      RX/TX seq numbers: 7681/7681
      SPI underruns 0, overruns 0
      State: 5, disconnects: 0, timeouts: 0 total, 0 by SBC, IAP RAM available 0x2b880
      Buffer RX/TX: 0/0-0, open files: 0
      === Duet Control Server ===
      Duet Control Server v3.4.1
      Code buffer space: 4096
      Configured SPI speed: 8000000Hz, TfrRdy pin glitches: 0
      Full transfers per second: 42.61, max time between full transfers: 63.6ms, max pin wait times: 53.6ms/32.5ms
      Codes per second: 0.34
      Maximum length of RX/TX data transfers: 3084/968
      Homegrown, grass fed and organically built 350mm delta
        jay_s_uk @Velvia
        @velvia said in Non-PWM hotend fan always on with thermostatic control:
        change this line to
        M106 P0 S1 H1 T60                                  ; set fan 0 value. Thermostatic control is turned on
        droftartsundefined Velviaundefined 2 Replies Last reply Reply Quote 0
          droftarts administrators @jay_s_uk
          @jay_s_uk I'm not sure the fan speed (S parameter) is very relevant when setting thermostatic control. You can leave it out, and the fan will be off when below the set temperature, and on at 100% when above that temperature (just tested). So setting initially off (S0), or on (S1), doesn't make a difference (also just tested).
          @Velvia More likely, I think, is that you have connected the fan -negative wire to GND, rather than the out5 pin. Fans are switched on the ground/negative side, by the out5 pin. Positive voltage supply is via the VOUTLC1 pin, which is 'always on', and not switched.
          Velviaundefined 2 Replies Last reply Reply Quote 3
          • Velviaundefined
            Velvia @jay_s_uk
            @jay_s_uk
            Nothing happened
            • Velviaundefined
              Velvia @droftarts
              @droftarts
              This is most likely the issue. Will try this.
              • Velviaundefined
                Velvia @droftarts
                @droftarts
                It worked! Thank you!
                • droftartsundefined droftarts marked this topic as a question
                • droftartsundefined droftarts has marked this topic as solved
