Write a plugin for DWC- solved using BtnCmd.
@moth4017 turn on Snap to Grid in tab settings
@mintytrebor
hi snap to grid was already on.if i turn off snap to grid and resize so they are the same , then turn on snap to grid , that works,
@moth4017 No
hi is it possible to use a global variable for the URL in a post request , where it says drybox in the picture below .
e.g global dryBoxName = "fred"
http://[dryBoxName}/calibrate -
@moth4017 You are trying to make it too small.
https://github.com/MintyTrebor/BtnCmd/wiki/Add-Edit-Panel
@moth4017 said in Looking for someone to write a plugin for DWC:
No
