Write a plugin for DWC- solved using BtnCmd.
Duet Web Control
4.3k
    MintyTrebor @moth4017
    @moth4017 take a new backup and replace the BtnCmdAutoRestore.json with the new version. Now open your printer in a private browser window, does it auto restore then?
    NodeDSF - Native Node-Red integration with Duet boards.
    BtnCmd - Customise DWC with user defined buttons/layouts/panels (DWC Plugin)
    ReleaseMgr - Duet update info inside DWC.
    Repo
      moth4017
      @mintytrebor
      Did a new backupAutoRestore file , opened up browser in "incognito" mode put in ip address of the printer , the BtnCmd file did not autorecover .
      undefined 1 Reply Last reply 14 Jul 2022, 11:39 Reply Quote 0
        @moth4017 when you click the "info" button in settings, what version does it report?
        Edit - On further thought, given your installation issues with the plugin version upgrade. I think it would be wise if you stop the plugin, uninstall it, clear your browser cache, download and install the plugin again, then re-test the auto restore feature with a fresh backup file.
        If that does not work send me your backup file please.
        Repo
        undefined 4 Replies Last reply 14 Jul 2022, 20:50 Reply Quote 0
          moth4017 @MintyTrebor
          @mintytrebor
          BtnCmd Beta v0.10.13
          Cobbled together by Minty Trebor
          BtnCmd uses the following libraries/modules:
          DeepMerge, MQTT.js, vue-draggable-resizable, axios, jsonpath, vuedraggable
          Plus re-uses components and code from DWC.
          BtnCmd Wiki
          Material Design Icon Library
          Ill do the unistall reinstall a bit later on today
            @mintytrebor
            Ok i did the unistall , create new file , do new back up etc etc
            opened new browser , and the restore worked, ill keep an eye on it while doing the software on the esp32. cheers
              moth4017 @moth4017
              This post is deleted!
                @mintytrebor
                Hi well , almot there , jus have some OCD things 🙂 now to sort
                how do i get the buttons and input boxes to line up.
                undefined 1 Reply Last reply 19 Jul 2022, 06:19 Reply Quote 0
                  @moth4017 turn on Snap to Grid in tab settings
                  Repo
                  undefined 1 Reply Last reply 19 Jul 2022, 07:03 Reply Quote 0
                    @mintytrebor
                    hi snap to grid was already on.
                    if i turn off snap to grid and resize so they are the same , then turn on snap to grid , that works,
                      @mintytrebor
                      Hi is there's an easy way to inherit the DWC styles in one of those html boxes,
                      so font, text colour, back ground colour etc is the same
                      undefined 1 Reply Last reply 21 Jul 2022, 15:56 Reply Quote 0
                        @moth4017 No
                        Repo
                        undefined 2 Replies Last reply 30 Jul 2022, 05:49 Reply Quote 0
                          moth4017
                          calibration page finished
                            moth4017
                            filament left on spool weight , with the spool weight removed .
                              @mintytrebor
                              hi is it possible to use a global variable for the URL in a post request , where it says drybox in the picture below .
                              e.g global dryBoxName = "fred"
                              http://[dryBoxName}/calibrate
                                @mintytrebor
                                hi when making an input button narrow there looks like another button in the back ground
                                undefined 1 Reply Last reply 5 Aug 2022, 08:15 Reply Quote 0
                                  @moth4017 You are trying to make it too small.
                                  https://github.com/MintyTrebor/BtnCmd/wiki/Add-Edit-Panel
                                  @moth4017 said in Looking for someone to write a plugin for DWC:
                                  No
                                  Repo
                                  undefined 1 Reply Last reply 6 Aug 2022, 23:38 Reply Quote 0
                                    moth4017
                                      @mintytrebor
                                      is there away to right justify the text in a "Edit Input Panel Settings"
                                      so the value is next to the suffix?
