Write a plugin for DWC- solved using BtnCmd.
@moth4017 when you click the "info" button in settings, what version does it report?
Edit - On further thought, given your installation issues with the plugin version upgrade. I think it would be wise if you stop the plugin, uninstall it, clear your browser cache, download and install the plugin again, then re-test the auto restore feature with a fresh backup file.
If that does not work send me your backup file please.
@mintytrebor
BtnCmd Beta v0.10.13
Cobbled together by Minty Trebor
BtnCmd uses the following libraries/modules:
DeepMerge, MQTT.js, vue-draggable-resizable, axios, jsonpath, vuedraggable
Plus re-uses components and code from DWC.
BtnCmd Wiki
Material Design Icon LibraryIll do the unistall reinstall a bit later on today
Ok i did the unistall , create new file , do new back up etc etc
opened new browser , and the restore worked, ill keep an eye on it while doing the software on the esp32. cheers -
This post is deleted! -
@moth4017 turn on Snap to Grid in tab settings
@mintytrebor
hi snap to grid was already on.if i turn off snap to grid and resize so they are the same , then turn on snap to grid , that works,
@moth4017 No
hi is it possible to use a global variable for the URL in a post request , where it says drybox in the picture below .
e.g global dryBoxName = "fred"
http://[dryBoxName}/calibrate -
@moth4017 You are trying to make it too small.
https://github.com/MintyTrebor/BtnCmd/wiki/Add-Edit-Panel
@moth4017 said in Looking for someone to write a plugin for DWC:
No
