Write a plugin for DWC- solved using BtnCmd.
@moth4017 said in Looking for someone to write a plugin for DWC:
Hi is there any reason why all the layouts disappeared when i took out the sd card and put it back in again?
No. BtnCmd only uses the SD card for backup/restore or AutoBackup. Loss of layouts normally are caused by IP address changes, or clearing browser cache.
The error msg is referring to the browser developer console not the gcode console (I need to make that clearer in the error msg). Turn on developer tools in the browser, and see what error msg is generated when you click the button.
@mintytrebor
cheers for the reply , it looks like it will be my browser cache as every time my PC starts it clears out the cache..so im playing around with the Global Variable Input Panels (Change/update the value of global variables)
ive set a "Edit Input Panel Settings" and set the global variable name , when i enetr a number then hit return i get this error message "
@mintytrebor you don't need to specify "global." in the variable name. Its added automatically as you can only update global variables. Just put the variable name in.
@mintytrebor works perfect now thanks
hi what have i not done correct to post a "global value".
@moth4017 I'm not sure if the HTTP post function is capable of using global variables. I'll have to check the code. Hopefully it won't be too much issue to add it for the next release.
thanks, is there away to display text, from a post from another device,
e.g we have the esp32 that will send a message (http) to your plugin "remove empty spool" or "place calibration weight " up to 4 messages needed
@moth4017 I'm not sure why you could not use the same approach as you have already done with global variables. Global's can be strings, numbers, or boolean's. Set up a variable to receive the text string, update it in the same way you have done with the other variables from your esp, and display it in a Object Model Panel.
Thanks will do testing today .
re backup auto recovery
"By renaming a standard BtnCmd backup file to BtnCmdAutoRestore.json in the SDCard SYS folder, BtnCmd will load the file automatically when any of the above conditions are met."The standard file name being "BtnCmdSettings" and rename this to BtnCmdAutoRestore.json is this correct?
I tried installing the new version over the top of the old one, first stopping the plugin , but my printer would not start after that so recreated the files on the SD card and installed the new version and thats working OK .
im getting this http message when i post this command
It's whatever you named the backup file when you created it. The default backup file name is BtnCmdSettings.json.
In the img there is no post data - so it cannot post anything.
im not sure if im using "post" correctly. it is working but the http error being reported.
"http://192.168.0.10/tare" is what i need to post. i have tried putting "tare" in the data field but this didnt work. i also tried using "Get" this works too but i get the same http error message . It also says "check Browser Console for more details " but there is never any details.
Other wise were about 80% of the way through the project .
Hi tried the { } still get the http error, are you expecting a returned code like 200?
@moth4017 when you type the Post URL into your browser what is returned?
putting this into the browser :- http://192.168.0.10/tare{}
"Path Not FoundURI: /tare%7B%7D
Method: GET
Arguments: 0"putting this into the browser :- http://192.168.0.10/tare
reply
"tare ok"the tare ok message is the response from the esp32
@mintytrebor
still having a few issues with post does this look correct
@moth4017 it's missing the http:// in the URL
