    Help with M671
    723
    • bilschundefined
      bilsch
      I'm working on a new printer build. I'm at the point where the bot prints but the M671 settings are wrong. Getting the correct values is where I'm stuck - the doc just does not make sense to me ( how to take values and populate the config )
      With my current M671:
      M671 X-67:-67:385:385 Y67:368:368:9 S20
      Its not clear to me how I need to come up with the measurements and then populate into the gcode command.
      I diagrammed the layout on my whiteboard. The measurements are taken from the corner of the bed to the center of the pivot ( eg at all 4 corners ) The blue dots represent the pivot point.
      I came up with
      M671 X-67:-67:385:385 Y67:385:385:10 S20
      Does this look right? ( If so I'm doing something wrong because its always lower in the back after running z home )
      Thoughts? What am I doing wrong here?
      • fcwiltundefined
        fcwilt @bilsch
        @bilsch
        Not much to go on there.
        I gather you are trying to level the bed?
        Did you generate the heightmap just to visualize the result?
        bilschundefined 1 Reply Last reply Reply Quote 0
        • bilschundefined
          bilsch @fcwilt
          @fcwilt so yea I'm trying to get my bed leveled. This is on a voron 2.4 - I have 4 independent pivot points ( belts, not leadscrew )
          M671 is configuring the plane. The problem is I don't get how to derive the numbers for that command.
          PaulHewundefined fcwiltundefined 3 Replies Last reply Reply Quote 0
          • PaulHewundefined
            PaulHew @bilsch
            @bilsch what are you using to level the bed? Inductive, BLT or Euclid.
            Also what size 2.4?
            P.
            RailCore II - Duet Mini + 1LC, Voron V0.1 - Duet Mini
            Voron 2.4 disassembled..... Waiting for the RailCore Mini....
            • PaulHewundefined
              PaulHew @bilsch
              @bilsch This is from Fulgs config....
              M671 X-65:-65:365:365 Y0:395:395:0 S20 ; Define Z belts locations (Front_Left, Back_Left, Back_Right, Front_Right)
              Which can be found here.
              https://github.com/Fulg/VoronUsers/blob/add-rrf3-config/firmware_configurations/reprapfirmware-duet3-mini5%2B/fulg/sys/config.g
              Use it as a reference, as it was created in 2021
              • fcwiltundefined
                fcwilt @bilsch
                @bilsch said in Help with M671:
                Well I don't know that printer but the numbers in M671 are in reference to X=0 Y=0.
                And you want to specify the places there the bed is actually being lifted, not where the belt is or the stepper is.
                In this image you can see the sphere the v-slot is riding on. The position of the sphere is what I use.
                • bilschundefined
                  bilsch @PaulHew
                  @paulhew 300x300. Using the euclid probe
                  • bilschundefined
                    bilsch @fcwilt
                    @fcwilt said in Help with M671:
                    I think this is the bit I was not understanding - all are referenced from x0,y0
                    The config referenced earlier by @PaulHew makes more sense now ( and the numbers are not too far from what I had actually )
                    • bilschundefined
                      bilsch @bilsch
                      Ok at this point with the information in the thread - its working now. I just used the values from the referenced config but I spot checked it on my bot - within 1mm so I just stuck with that
                      I consider this resolved 😉 thanks @fcwilt !
