    How can I read the machine position for conditionals?
    CNC
    • TQKez 0undefined
      TQKez 0
      E.g there are lots of relative moves on the z axis that are there to move the head out of the way in the homing code. But being a CNC, the z position is often already near max.
      How could I say e.g (pseudo code)
      if ("z axis position" < 50) {
      ...do the relative z move up
      } else {
      ...do nothing.
      OwenDundefined 1 Reply Last reply Reply Quote 0
      • OwenDundefined
        OwenD @TQKez 0
        @tqkez-0
        Something like this will do it
        if {(move.axes[2].machinePosition) < (move.axes[2].max - 10)} ; check if there's sufficient space to raise head
        	M291 P{"Raising head to...  Z" ^ (move.axes[2].machinePosition+5)}  R"Raising head" S0 T2
        	G91 ; relative positioning
        	G1 Z5 F120 ; move Z up a bit
        	G90 ;absolute positioning
        TQKez 0undefined 1 Reply Last reply Reply Quote 1
        • TQKez 0undefined
          TQKez 0 @OwenD
          @owend said in How can I read the machine position for conditionals?:
          @tqkez-0
          Perfect thanks!
          I've trying to find the list of variables that can be accessed, but i can only seem to find info in the docs about creating custom variables. Is there a list somewhere?
          HebigTundefined 1 Reply Last reply Reply Quote 0
          • HebigTundefined
            HebigT @TQKez 0
            @tqkez-0
            Check out the object model. https://duet3d.dozuki.com/Wiki/Object_Model_of_RepRapFirmware
            DuetWebControl also includes an object model plugin (at least newer versions do). Run that and you should be able to access the position for each axis and reference it using variations of @TQKez-0's example.
