    Paneldue 7i not working an Duet 3 mini5+ WiFi
    PanelDue
    471
    • arnd13undefined
      arnd13
      I have a problem with a Paneldue 7i in combination with Duet 3 mini5+ WiFi.
      The display is receiving data from board on boot up. Showing established wifi connection etc.
      but is showing "connecting" in the top right corner of the display and the buttons for homing etc. don't work.
      I've tried different things to get it working.
      One funny thing I discovered. When I'm flashing the display firmware update within the webinterface of the board. The board flashes the display with status OK and the display works perfectly. The buttons for homing etc. work perfectly.
      But when I restart the board/printer the display doesn't work and shows the status "connecting" again.
      Firmware on all parts (Board, DWC and Paneldue) is 3.4.0. Connected with 10-wire cable but using the 4-wire cable gives the same result.
        dc42 administrators @arnd13
        @arnd13 do you have this command in config.g:
        M575 P1 S1 B57600
        The baud rate in this command (57600 in this case) must match the baud rate configured on the PanelDue Setup page.
        • arnd13undefined
          arnd13
          config.g contains the parameter above. The PanelDue is configured to the same baud rate.
          The settings must be right. When I change the rate the message with "established WiFi connection" is also gone. With 57600 baud I get the "established WiFi connection" message, so I think the baud rate ist right.
          The funny thing ist, that everything works directly after flashing the PanelDue from the duet board.
          It seems that the board sends a special command while flashing.....
            Please post the contents of your config.g and the results of sending M122 in the gcode console of DWC.
            arnd13undefined 3 Replies Last reply Reply Quote 0
            • arnd13undefined
              arnd13 @Phaedrux
              @phaedrux
              Here ist the content of config.g:
              ; Configuration file for Duet 3 Mini 5+ (firmware version 3.3)
              ; generated by RepRapFirmware Configuration Tool v3.3.10 on Thu Jul 07 2022 10:07:15 GMT+0200 (Mitteleuropäische Sommerzeit)
              M550 P"Ender 5" ; set printer name
              M552 S1 ; enable network
              M586 P0 S1 ; enable HTTP
              M586 P1 S0 ; disable FTP
              M586 P2 S0 ; disable Telnet
              M569 P0.1 S1 ; physical drive 0.1 goes forwards
              M569 P0.2 S0 ; physical drive 0.2 goes backwards
              M569 P0.3 S0 ; physical drive 0.3 goes backwards
              M584 X0.0 Y0.1 Z0.2 E0.3 ; set drive mapping
              M92 X80.00 Y80.00 Z400.00 E93.00 ; set steps per mm
              M566 X1200.00 Y1200.00 Z24.00 E300.00 ; set maximum instantaneous speed changes (mm/min)
              M203 X9000.00 Y9000.00 Z180.00 E6000.00 ; set maximum speeds (mm/min)
              M201 X500.00 Y500.00 Z100.00 E5000.00 ; set accelerations (mm/s^2)
              M906 X800 Y800 Z800 E1000 I20 ; set motor currents (mA) and motor idle factor in per cent
              M84 S10 ; Set idle timeout
              M208 X235 Y235 Z260 S0 ; set axis maxima
              M574 X1 S1 P"io0.in" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin !io0.in
              M574 Y1 S1 P"io1.in" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin !io1.in
              M574 Z1 S1 P"io2.in" ; configure switch-type (e.g. microswitch) endstop for low end on Z via pin !io2.in
              M950 S0 C"io3.out" ; create servo pin 0 for BLTouch
              M558 P9 C"io3.in+io4.out" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
              G31 P500 X0 Y0 Z2.5 ; set Z probe trigger value, offset and trigger height
              M557 X15:215 Y15:195 S20 ; define mesh grid
              M308 S0 P"temp0" Y"thermistor" T100000 B3850 ; configure sensor 0 as PT1000 on pin temp0
              M143 H0 S150 ; set temperature limit for heater 0 to 150C
              M308 S1 P"temp1" Y"thermistor" T100000 B3850 ; configure sensor 1 as PT1000 on pin temp1
              M950 H1 C"out1" T1 ; create nozzle heater output on out1 and map it to sensor 1
              M307 H1 B1 S1.00 ; disable bang-bang mode for heater and set PWM limit
              M143 H1 S275 ; set temperature limit for heater 1 to 275C
              M950 F0 C"out3" Q500 ; create fan 0 on pin out3 and set its frequency
              M950 F1 C"out5" Q500 ; create fan 1 on pin out5 and set its frequency
              M950 F2 C"out4" Q500 ; create fan 2 on pin out4 and set its frequency
              M106 P2 S1 H1:0 T45 ; set fan 2 value. Thermostatic control is turned on
              T0 ; select first tool
              • arnd13undefined
                arnd13 @Phaedrux
                @phaedrux
                and the result of M122:
                M122
                RepRapFirmware for Duet 3 Mini 5+ version 3.4.0 (2022-03-15 18:59:15) running on Duet 3 Mini5plus WiFi (standalone mode)
                Board ID: 9W38H-X196U-D65J0-40KMJ-LR03Z-76LRD
                Used output buffers: 3 of 40 (13 max)
                Static ram: 103684
                Dynamic ram: 110608 of which 0 recycled
                Never used RAM 27420, free system stack 204 words
                Tasks: NETWORK(ready,14.9%,240) HEAT(notifyWait,0.0%,358) Move(notifyWait,0.0%,363) CanReceiv(notifyWait,0.0%,942) CanSender(notifyWait,0.0%,372) CanClock(delaying,0.0%,339) TMC(notifyWait,0.7%,114) MAIN(running,83.4%,428) IDLE(ready,0.1%,29) AIN(delaying,0.8%,273), total 100.0%
                Owned mutexes: WiFi(NETWORK)
                Last reset 00:03:29 ago, cause: power up
                Last software reset at 2022-07-09 13:48, reason: User, GCodes spinning, available RAM 27492, slot 1
                Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00000000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a
                Error status: 0x00
                Aux0 errors 0,0,1
                MCU revision 3, ADC conversions started 209714, completed 209714, timed out 0, errs 0
                Step timer max interval 753
                MCU temperature: min 22.0, current 32.4, max 32.4
                Supply voltage: min 24.2, current 24.3, max 24.4, under voltage events: 0, over voltage events: 0, power good: yes
                Events: 1 queued, 1 completed
                Driver 0: standstill, SG min 0, read errors 0, write errors 0, ifcnt 9, reads 10990, writes 9, timeouts 0, DMA errors 0, CC errors 0
                Driver 1: standstill, SG min 0, read errors 0, write errors 0, ifcnt 9, reads 10990, writes 9, timeouts 0, DMA errors 0, CC errors 0
                Driver 2: standstill, SG min 0, read errors 0, write errors 0, ifcnt 9, reads 10990, writes 9, timeouts 0, DMA errors 0, CC errors 0
                Driver 3: standstill, SG min 0, read errors 0, write errors 0, ifcnt 9, reads 10990, writes 9, timeouts 0, DMA errors 0, CC errors 0
                Driver 4: standstill, SG min 0, read errors 0, write errors 0, ifcnt 9, reads 10990, writes 9, timeouts 0, DMA errors 0, CC errors 0
                Driver 5: not present
                Driver 6: not present
                Date/time: 2022-07-12 18:07:11
                Cache data hit count 397677381
                Slowest loop: 5.59ms; fastest: 0.13ms
                === Storage ===
                Free file entries: 10
                SD card longest read time 0.9ms, write time 0.0ms, max retries 0
                DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, comp offset 0.000
                === MainDDARing ===
                === AuxDDARing ===
                Segments left: 0
                Movement lock held by null
                HTTP is idle in state(s) 0
                Telnet is idle in state(s) 0
                File is idle in state(s) 0
                USB is idle in state(s) 0
                Aux is assembling a command in state(s) 0
                Trigger is idle in state(s) 0
                Queue is idle in state(s) 0
                LCD is idle in state(s) 0
                SBC is idle in state(s) 0
                Daemon is idle in state(s) 0
                Aux2 is idle in state(s) 0
                Code queue is empty
                === CAN ===
                Messages queued 1883, received 0, lost 0, boc 0
                Longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 18 (min 18), ts 1047/0/0
                Tx timeouts 0,0,1046,0,0,835 last cancelled message type 30 dest 127
                === Network ===
                Slowest loop: 15.63ms; fastest: 0.00ms
                HTTP sessions: 1 of 8
                • WiFi -
                  Network state is active
                  WiFi firmware version 1.26
                  WiFi MAC address f0:08:d1:03:80:32
                  WiFi Vcc 3.28, reset reason Power up
                  WiFi flash size 2097152, free heap 27144
                  WiFi IP address 192.168.141.44
                  WiFi signal strength -52dBm, mode 802.11n, reconnections 0, sleep mode modem
                  Clock register 00002002
                Thank you.
                • arnd13undefined
                  arnd13 @Phaedrux
                  @phaedrux
                  Board was used solo with the PanelDue and not connected to the printer parts.
                    droftarts administrators @arnd13
                    @arnd13 how is the PanelDue connected? If it’s via the ribbon cable, you cannot have anything connected on io_0, as they share pins. According to your config, you have an endstop on that. Move the X endstop to a different IO connector.
                    arnd13undefined 1 Reply Last reply Reply Quote 1
                    • arnd13undefined
                      arnd13 @droftarts
                      @droftarts
                      That was the fault in the config. Now it's running 👍
                      I saw the mark in the wiring diagram but didn't thought about it 😬
                      Thank you so much.
