    Error: M552: Network-related cmds r not supported using SBC
    Firmware installation
    725
    • foesiundefined
      foesi
      I purchased a new Duet 3 mini 5+ from 'cr3d.de' a few weeks ago.
      Now I wanted to setup the duet with YAT but somehow this error occurs when I type in M552
      -> Error: M552: Network-related commands are not supported when using an attached Single Board Computer
      When I type in M115 it tells me this
      ->FIRMWARE_NAME: RepRapFirmware for Duet 3 Mini 5+ FIRMWARE_VERSION: 3.4.1 ELECTRONICS: Duet 3 Mini5plus WiFi FIRMWARE_DATE: 2022-06-01 21:07:06
      I also have tried to reformat the SD-card like explained but there is still no difference. By searching for a dead SD-card reader I found out to check the M122 which tells me this
      ->=== Storage ===
      Free file entries: 10
      SD card 0 not detected, interface speed: 0.0MBytes/sec
      Is the problem with the M552 connected with a dead SD-card reader? Or is there another problem?
      Any guesses appreciated!
        jay_s_uk @foesi
        @foesi looks like it. I take it you aren't using an SBC and the SD card is formatted as FAT32?
        foesiundefined 1 Reply Last reply Reply Quote 0
        • foesiundefined
          foesi @jay_s_uk
          @jay_s_uk that is correct.
          The SD-card is FAT32 and I have no SBC connected.
            jay_s_uk @foesi
            @foesi one for @Phaedrux
            can you confirm when a few weeks ago was?
            • foesiundefined
              foesi @jay_s_uk
              @jay_s_uk yes sure I can send you the details per Mail.
              A few weeks ago means I purchased it at 03.07.2022
                Can you share the entire results of M122?
                What do the contents of the SD card look like?
                • foesiundefined
                  foesi @Phaedrux
                  @phaedrux here are the results of M122 and the contents of the SD-card.
                  Screenshot 2022-07-12 103321.png Screenshot 2022-07-12 103220.png Screenshot 2022-07-12 103107.png
                  m122
                  RepRapFirmware for Duet 3 Mini 5+ version 3.4.1 (2022-06-01 21:06:56) running on Duet 3 Mini5plus WiFi (SBC mode)
                  Board ID: KS8ZD-NT8LU-F65J0-409NL-1513Z-7LQYL
                  Used output buffers: 1 of 40 (1 max)
                  Static ram: 103684
                  Dynamic ram: 96528 of which 0 recycled
                  Never used RAM 41500, free system stack 170 words
                  Tasks: SBC(notifyWait,0.0%,972) HEAT(notifyWait,0.0%,374) Move(notifyWait,0.0%,363) CanReceiv(notifyWait,0.0%,942) CanSender(notifyWait,0.0%,372) CanClock(delaying,0.0%,339) TMC(notifyWait,0.0%,123) MAIN(running,98.4%,583) IDLE(ready,0.8%,29) AIN(delaying,0.8%,274), total 100.0%
                  Owned mutexes: USB(MAIN)
                  Last reset 00:00:12 ago, cause: power up
                  Last software reset details not available
                  Error status: 0x00
                  MCU revision 3, ADC conversions started 12868, completed 12868, timed out 0, errs 0
                  Step timer max interval 1490
                  MCU temperature: min 10.4, current 13.5, max 13.5
                  Supply voltage: min 0.4, current 0.9, max 0.9, under voltage events: 0, over voltage events: 0, power good: no
                  Events: 0 queued, 0 completed
                  Driver 0: ok, SG min n/a, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0, CC errors 0
                  Driver 1: ok, SG min n/a, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0, CC errors 0
                  Driver 2: ok, SG min n/a, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0, CC errors 0
                  Driver 3: ok, SG min n/a, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0, CC errors 0
                  Driver 4: ok, SG min n/a, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0, CC errors 0
                  Driver 5: ok, SG min n/a, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0, CC errors 0
                  Driver 6: ok, SG min n/a, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0, CC errors 0
                  Cache data hit count 31761453
                  Slowest loop: 0.23ms; fastest: 0.00ms
                  === Storage ===
                  DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, comp offset 0.000
                  === MainDDARing ===
                  === AuxDDARing ===
                  Bed heaters -1 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0
                  Segments left: 0
                  Movement lock held by null
                  HTTP is idle in state(s) 0
                  Telnet is idle in state(s) 0
                  File is idle in state(s) 0
                  USB is ready with "m122" in state(s) 0
                  Aux is idle in state(s) 0
                  Trigger is idle in state(s) 0
                  Queue is idle in state(s) 0
                  LCD is idle in state(s) 0
                  SBC is idle in state(s) 0
                  Daemon is idle in state(s) 0
                  Aux2 is idle in state(s) 0
                  Code queue is empty
                  === CAN ===
                  Messages queued 64, received 0, lost 0, boc 0
                  Longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 18 (min 18), ts 64/0/0
                  Tx timeouts 0,0,63,0,0,0 last cancelled message type 30 dest 127
                  === SBC interface ===
                  Transfer state: 0, failed transfers: 0, checksum errors: 0
                  RX/TX seq numbers: 0/1
                  SPI underruns 0, overruns 0
                  State: 0, disconnects: 0, timeouts: 0 total, 0 by SBC, IAP RAM available 0x0f1ec
                  Buffer RX/TX: 0/0-0, open files: 0
                  ok
                    droftarts administrators @foesi
                    @foesi It looks like the Duet isn't seeing the SD card socket at all, so likely a soldering fault on the socket or one of the components nearby. Unfortunately these faults happen from time to time, despite factory testing. We are happy to offer you a warranty replacement, and sorry for the inconvenience.
                    Please send an email to warranty@duet3d.com and CC your reseller. Include a link to this forum thread and the details of your original purchase. You'll receive a reply with a form to fill out.
                    • foesiundefined
                      foesi
                      I recently got the new duet board and - it works fine now! Thanks for your help!
                      It must have been the SD-card socket. Now I can get on with my project - which is to make the Duet 3 mini 5+ my controller for a Tronxy X5SA-600.
                      Thanks again and all in all it was surprisingly convenient to get the new board.
