(Solved)Please help me find a pinout chart for the duetWifi
(To answer my question the duetWifi pictured below is an earlier version of the Duet 2 Wifi with the same pinout. Please see post from droftarts below)
Hello All, I am looking for a pinout chart for the duetWifi it may also be know as the Duet 2nd Gen. Can any one point me in the right direction?
@ccdanieldb
Here you should find all the information you need about the board.
https://docs.duet3d.com/Duet3D_hardware/Duet_2_family/Duet_2_WiFi_Ethernet_Hardware_OverviewCould also be interesting for you !?
https://docs.duet3d.com/en/How_to_guides/Wiring_your_Duet_2 -
@günter-jibben Thank you for the link. I was able to find a pinout for the Duet2Wifi at this link https://duet3d.dozuki.com/Wiki/Duet_2_Pinout_table
But I was not able to find a pinout for the older DuetWifi pictured above.
@ccdanieldb it’s the same, just the name changed from DuetWiFi to Duet 2 WiFi when the Ethernet version launched. There have been different versions over time, but essentially the same. See the ‘Revisions’ section on this page https://docs.duet3d.com/Duet3D_hardware/Duet_2_family/Duet_2_WiFi_Ethernet_Hardware_Overview
@droftarts Thank you for letting me know, I now see in the version history where its name was changed after ver1.05. I will change this to solved.
