    Another Temp daughterboard problem
    207
    • larrylfundefined
      larrylf
      I'm in the process of setting up a printer with a duet3 mini 5+. I have the temperature daughterboard for it, and am tried to set it up in my config file.
      From the documentation, it looks like I should use M308:
      M308 S3 Y"thermistor" P"spi.cs1" T100000 B4138
      But when it boots up, I get an error "pin spi.cs1 doesn't support analog input"
      What am I doing wrong?
      Phaedruxundefined dc42undefined 2 Replies Last reply Reply Quote 0
        Phaedrux Moderator @larrylf
        @larrylf said in Another Temp daughterboard problem:
        Can you be more specific? Is it a PT100 or thermocouple daughterboard?
        https://docs.duet3d.com/en/Duet3D_hardware/Accessories/PT100_Temperature_Daughterboard
        https://docs.duet3d.com/en/Duet3D_hardware/Accessories/Thermocouple_Daughterboard
        larrylfundefined 1 Reply Last reply Reply Quote 0
          dc42 administrators @larrylf
          @larrylf the Y parameter in your M308 command is wrong. The sensor is not a thermistor.
          • larrylfundefined
            larrylf @Phaedrux
            @phaedrux Sorry, it is the PT100 board, and I am using a thermistor in it.
            • larrylfundefined
              larrylf @dc42
              @dc42 Oh, so you're saying that I have to identify it as the board, not what its used for?
              I'll try to find what it should be, then
              • larrylfundefined
                larrylf @larrylf
                @larrylf yes, that worked - thank you
                  droftarts administrators @larrylf
                  @larrylf you are not going to get accurate temperatures using a thermistor with the PT100 board. As temperature increases, a thermistor’s resistance decreases; a PT100’s resistance increases. So a thermistor connected to the PT100 board will report a drop in temperature as temperature increases.
                  You can connect a thermistor or PT1000 directly to the temperature inputs on the Duet; you don’t need a daughterboard.
                  • larrylfundefined
                    larrylf @droftarts
                    @droftarts yes, the thermistor was a mistake - in fact, I seem to have the wrong sensors everwhere (PT100's in the mainboard TEMP, thermistor in the daughterboard). 😞
                    Fixed now, but frustrating...
