    Duex Controlled Fan Failure
    • JRCLundefined
      JRCL
      Hello all,
      I have 4 fans on my machine, the first 3 being connected to my Duet 2 Wifi and the 4th on the Duex board. However, FAN3, the one on the Duex board, does not seem to want to work.
      Upon powering up the machine, FAN3 moves slightly but after troubleshooting it for a while I noticed it smelled a little burnt or like it was stalling. I switched fans to make sure the hardware wasn't the issue and the second fan acted the same way.
      As you can see FAN3 is set up the exact same as FAN2 and is the same fan even but it is connected to the Duex board seems to be the difference. I also have tried using C"duex.fan3" and C"^duex.fan3" instead of C"fan3" but that didn't solve it either
      Here is my config.g
      ;Part Cooling
      M950 F0 C"fan0" Q500 							; create fan 0 on pin fan0 and set its frequency
      M106 P0 S0 H-1       							; set fan 0 value. Thermostatic control is turned off
      ;Heatsink
      M950 F1 C"fan1" Q500 							; create fan 1 on pin fan1 and set its frequency
      M106 P1 S1 H1 T20    							; set fan 1 value. Thermostatic control is turned on
      ;OHE Fan 1
      M950 F2 C"fan2" Q500 							; create fan 2 on pin fan1 and set its frequency
      M106 P2 S1 H2 T20    							; set fan 2 value. Thermostatic control is turned on
      ;OHE Fan 2
      M950 F3 C"fan3" Q500 							; create fan 3 on pin fan1 and set its frequency
      M106 P3 S1 H2 T20    							; set fan 3 value. Thermostatic control is turned on
      Here are the fans:
      https://www.amazon.com/gp/product/B07THFT6NT/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
      alankilianundefined 1 Reply Last reply Reply Quote 0
      • JRCLundefined JRCL marked this topic as a question
      • alankilianundefined
        alankilian @JRCL
        @jrcl How do you have the everything connected and what do you have for fan setting jumpers?
        HERE is the page describing how to connect fans to the Duex board..
        JRCLundefined 1 Reply Last reply Reply Quote 0
        • JRCLundefined
          JRCL @alankilian
          @alankilian
          All jumpers are still in their default position and match what's shown in both diagrams
          -Duet2
          -Duex
          In other words, everything is set up to run 5V currently. FAN3 is mounted on the FAN3 pin alongside the other PWM fans on the Duex
          alankilianundefined 1 Reply Last reply Reply Quote -1
            alankilian @JRCL
            @jrcl OK, that probably explains it.
            If you have the VFan set to Vin, you'll put either 12 or 24 Volts across your 5 Volt fan depending on what voltage you have on VIN
            JRCLundefined 1 Reply Last reply Reply Quote 3
            • JRCLundefined
              JRCL @alankilian
              @alankilian That did it! RIP quite a few 5V fans 😁
              • JRCLundefined JRCL has marked this topic as solved
                alankilian @JRCL
                @jrcl
                EXCELLENT!!!
                Have fun printing!
