Why are "custom GCodes" only for non implemended GCodes?
@owend amen.
@owend said in Why are "custom GCodes" only for non implemended GCodes?:
I think substituting already defined G/M codes probably opens up Pandora's box in terms of being able to support RFF.
Is it really substituting? In my understanding, it is rather a redirection to call a macro rather than executing the native Gcode directly
There are a lot of codes that are interdependent on other codes.
I understand, but what I am proposing would not touch the "native" Gcode. On one Hand, I agree that customization does not make sense for all available Gcodes. On the other hand, it can be an incredibly powerful tool for adding custom behaviors and routines to our machines by giving users the option of combining Gcodes that are already there in a simple manner, Inside RRF and without the need for slicer scripts or custom post processors.
Support would no longer be a "post your config" scenario, it'd be "upload your SD contents"
The same is true right now when you are using macros, Mesh.g, Bed.g, daemon.g e.t.c, which we basically all do. It really depends on where the problem is coming from.
@owend said in Why are "custom GCodes" only for non-implemented GCodes?:
Post processing achieves the desired results without affecting the vast majority that don't need this option.
No it does not, otherwise we would not have this discussion. Furthermore, I see a lot of feature requests that can be simply solved with custom Gcodes. The thing is that this is already working for a list of non-implemented and some native Gcodes like G32, G29 and so on. Furthermore, the "vast majority" does also not use CNC-specific Gcodes either, but a whole list of non-implemented CNC-Gcodes is checked when called. So my proposal to only check for custom and non-Implemented Gcodes ,that are for example defined in config.g, will probably even reduce the overhead.
Thanks for the suggestions.
@maxgyver I'm struggling to understand...........In your OP you stated........
For me, it would be a huge deal to be able to adjust the behavior of standard G codes by simply adding the desired function via a macro file.
and......
For example, I would like to check if the enclosure door of my CNC is closed, move the Z-axis to a safe hight and set the Spindle speed using a separate macro whenever M3 is called.
And from what I can gather, you want to do this by modifying the behaviour of the gcode rather than use a stand alone macro. So taking your example of modifying the behaviour of M3, you want to check the enclosure door first, then move the Z axis, then set the spindle speed. But if you modify the behaviour of M3, to do all that, how are you going to set the spindle speed? You can't call/use M3 from within the macro because you've changed the behaviour such that it will check the door and move the Z axis which will just end up with a recursive call. By modifying the behaviour of the standard gcode, you no longer have any means of just setting the spindle speed. So you'd need to define another gcode to do that which you can then use with the macro that runs whenever M3 is encountered. Am I being thick? Have I misunderstood? I don't get why you can't just use a macro and how or why modifying the behaviour of existing gcode commands is going to be better.
Hey @deckingman,
I don't get why you can't just use a macro [...]
Some examples:
My printers have CPAP blowers+ Motor-valves instead of fans.
In order to control the valves, I would need to change the slicers post processor or use the search and replace function (if the slicer supports it) to add my custom code. While this works for files being printed from SD, I can't adjust the airflow from the web interface using the fan control sliders or just call M106 from the console. So basically the standard Gcode to control the Fans does not work for my setup. -
Similar with M3:
Of course, I can write a macro, let's say M3.1.g and change the CNC-Mill-post processor, to call the macro instead of the standard M3 code. But again, If I start the spindle from the web interface the standard code is called instead of my M3.1.g
The proposed logic would be as follows:
if Standard Gcode (like M3) is called
->check if a macro file with the same name (M3.g) is present
--> If yes, call this macro instead.
else
->continue with the standard Gcode (M3)@deckingman said in Why are "custom GCodes" only for non implemended GCodes?:
And that's where I absolutely agree. My logic only works if the standard Gcode that has called the macro is not included in the macro itself. For me, this would already solve a lot of problems...But Okay.
So we would need to find a way to prevent the recursive calling. One idea would be to execute the standard M3 code directly If it is being called from a macro file, without checking for custom Gcode files beforehand. And If M3 is called from slicer file or web interface or console do the check for a custom Gcode file in sys first and if it is present call it instead.
As an alternative, we could leave the standard codes like M3 untouched but add something like pre.M3.g and post.M3.g where we can add everything that should happen before and/or after the standard M3 call.
I hope this clears things up a little
Cheers
Max -
