    Mesh Bed Compensation Does Not Seem to Work
    Using Duet Controllers
    • Arakahnundefined
      Arakahn
      I will be referring to a previous thread, as I have the exact same issue and it was marked as Solved without an actual resolution posted:
      https://forum.duet3d.com/topic/21448/will-not-load-mesh-using-g29-s1-command/13?loggedin=true
      So basically the probing works fine (sorta, need to tweak my piezo probing). The height map is there and quite uneven.
      My start gcode seems to be ok:
      G91 ; relative positioning
      G90 ; absolute positioning
      ;G1 X70.5 Y-11 F6000 ; go to first probe point
      ;G30 ; home Z by probing the bed
      G29 S1
      M376 H10
      When sending an M122 I can see that bed compensation is on and using the heightmap, but physically no compensation is happening (the Z axes are not moving at all during the print outside changing layers).
      I am attaching my config and homing files. Any insight would be super appreciated 🙂
      homez.g homey.g homex.g homeall.g config.g bed.g
        M566 X600.00 Y600.00 Z0.00
        Is Z jerk 0 correct?
        Can you show a screenshot of the heightmap display?
        M376 H10
        Have you tried turning off the taper? M376 H0?
        Arakahnundefined 1 Reply Last reply Reply Quote 1
        • Arakahnundefined
          Arakahn @Phaedrux
          @phaedrux said in Mesh Bed Compensation Does Not Seem to Work:
          M566
          Wow... talk about not seeing the forest from the trees.
          I went over my settings 5 times, tried a bunch of things, and not ONCE did I even notice that. Probably changed my jerk and accidentally deleted the 5 from the 50 without noticing.
          Thank you @Phaedrux!
          If you don't mind I'll go get some rum and go feel stupid in my corner now.
