    RRF config tool won't add expansion boards
    Config Tool
    516
    • AQUATICLIFEundefined
      AQUATICLIFE
      Hi there, new to RRF. I'm trying to configure a Duet 3 mini 5+ and add in the TOOL1LC expansion board. There are multiple expansion boards listed but it will not allow me to select any of them. Is this a glitch? How do I proceed?
      Thanks!
        droftarts administrators @AQUATICLIFE
        @aquaticlife The config tool was updated yesterday, and a bug seems to have been introduced, sorry. One for @chrishamm to fix.
        AQUATICLIFEundefined 1 Reply Last reply Reply Quote 0
        • A Former User?
          A Former User
          This post is deleted!
          Rushmere3Dundefined 1 Reply Last reply Reply Quote 0
          • Rushmere3Dundefined
            Rushmere3D @A Former User
            @herve_smith Have selected a pin under I/O mapping? Without those you can't select endstops or z probe but you can when set.
            The first fan is the part cooling fan and so not suitable for this.
            Follow my adventures in 3D Printing, laser cutting and electronics. https://linktr.ee/Rushmere3D
            • A Former User?
              A Former User @Rushmere3D
                @herve_smith What duet board?
                  @herve_smith I’ve checked, and making valid choices for output pins on the I/O mapping page, using Mini 5+, all of the things you note as unselectable are selectable. There’s still an issue adding expansion boards, though. See the configuration guide for guidance using the config tool: https://docs.duet3d.com/en/How_to_guides/Configuring_firmware
                    AQUATICLIFE @droftarts
                    @droftarts Do you know approximately how long it'll be before the bug fix? I have a number of other things to do to my printer in the meantime, just not sure if its a days, weeks, months, kind of thing. Cheers.
                    jay_s_ukundefined droftartsundefined 2 Replies Last reply Reply Quote 0
                      jay_s_uk @AQUATICLIFE
                      @aquaticlife ignore adding them in the config tool and do it manually. Other than setting up X Y Z with single motors you need to edit your config anyway. And its better to learn what's going on with the config than rely on something that's autogenerated
                        @aquaticlife I expect @chrishamm will fix it early in the week. For examples of configuration with expansion/toolboard, see https://docs.duet3d.com/User_manual/Machine_configuration/Configuration_cartesian
                          @droftarts it's working now. Super excited to get started!
