Operate Micro Sub Servo on Duet Wifi ?
  • undefined
    Norder
    Can I connect such Micro Sub Servos to a Duet Wifi ?
    Unfortunately I could not find any information on this.
    I am planning to build a bed level sensor myself that requires a servo.
    Here are two examples of the servos I mean...
    KPower P0090 Micro (Alibaba)
    Spektrum Mini Linear Servo (Conrad Electronik)
    These are just examples, whether it will be one of the servos is still unclear.
    Maybe someone has a link to a description or video where such a micro servo is connected to a Duet and operated ?
    Google Translate
    ----- Original Text -----
    Kann ich an einen Duet Wifi solche Micro Sub Servos anschließen ?
    Leider konnte ich dazu keine Infos finden.
    Ich plane einen Bett-Level-Sensor selber zu bauen der einen Servo benötigt.
    Hier mal zwei Beispiele welche Servos ich meine...
    Es sind nur Beispiele, ob es einer von den Servos werden wird, ist noch unklar.
    Vielleicht hat auch jemand einen Link zu einer Beschreibung oder Video, wo so ein Micro Servo an einem Duet angeschlossen und betrieben wird ?
    DDA5X... 0.9° Stepper... Linearrails... Duet 2 Wifi... PT100 Board... Duet IR-Probe... Dyze Pro Kit up to 500°C.. etc
    Thingiverse
    undefined undefined 2 Replies Last reply 8 Aug 2022, 03:26 Reply Quote 0
    • undefined
      alankilian @Norder
      @norder Those will work perfectly just as a larger hobby servo would work.
      • undefined
        droftarts administrators @Norder
        @norder See https://docs.duet3d.com/User_manual/Connecting_hardware/Motors_servos
        From https://docs.duet3d.com/User_manual/Connecting_hardware/Motors_servos#hobby-servo-specification-examples
        There are many different types of hobby servos, and we do not recommend any particular one. Check the specification of any servo you connect to your Duet, in particular the idle, running and stall current. Generally, so-called '9g' servos should be okay to connect directly ... but larger servos should have additional protection, or be powered independently of the Duet.
        The two servos you list are 9g servos, but the the idle, running and stall current are not listed in their specification.
        1 out of 3
