    Using echo to write segmented values
    Gcode meta commands
    • ComedianTF2undefined
      ComedianTF2
      Hi all, I've been working on a macro to try and write the results from the PID tuning process automatically to a file, so that you wouldn't be required to amend your config.g manually
      In this, the one piece I can't figure out is how to write a segmented value
      The results from the PID tune in my case were:
      M307 H0 R2.009 K0.289:0.080 D4.65 E1.35 S1.00 B0 V23.9
      This is the code I use to write the file:
      echo >"0:/sys/config_PID_tune_E0.g" "M307 H0 R"^{heat.heaters[0].model.heatingRate}, "K"^{heat.heaters[0].model.coolingRate}, {heat.heaters[0].model.fanCoolingRate}, "D"^{heat.heaters[0].model.deadTime}, "E"^{heat.heaters[0].model.coolingExp}
      echo >>"0:/sys/config_PID_tune_E0.g" "M307 H0 B0 S1.0 V"^{heat.heaters[0].model.standardVoltage}
      Due to the character limit, it had to be executed in 2 lines rather than one, as the full string is around 290 characters long. It can be made into one line using variables, but that's not an issue in my eyes.
      With the K as written in the code snippet it results in the following config_PID_tune_E0.g
      M307 H0 R2.009 K0.289 0.080 D4.7 E1.4
      M307 H0 B0 S1.0 V23.9
      As you can see, there is a space between the two K values (it should be K0.289:0.080
      The K value is the one I can't figure out. With the way the echo command works, it expects either a , or a } at the end of any variable, so I'm not able to write it like I would expect it to need to work:
      "K"^{heat.heaters[0].model.coolingRate, heat.heaters[0].model.fanCoolingRate}
      With that code, I get the following error:
      Error: in file macro line 7 column 124: meta command: expected '}'
      Does anyone have insight on how to properly write the code?
      alankilianundefined 1 Reply Last reply Reply Quote 0
      • alankilianundefined
        alankilian @ComedianTF2
        @comediantf2 said in Using echo to write segmented values:
        Try:
        "K"^{heat.heaters[0].model.coolingRate},":", {heat.heaters[0].model.fanCoolingRate}
        There will be spaces around the ":" but I don't think that will matter.
        Give it a try and let us know.
        ComedianTF2undefined 1 Reply Last reply Reply Quote 1
          ComedianTF2 @alankilian
          @alankilian Sadly it looks like the spaces matter.
          The first M307 H0 was with the spaces (so K0.289 : 0.080), the second one without
          infiniteloopundefined 1 Reply Last reply Reply Quote 0
          • infiniteloopundefined
            infiniteloop @ComedianTF2
            @comediantf2 Don't use a comma, use the caret to concatenate the values:
            "K"^{heat.heaters[0].model.coolingRate}^":"^{heat.heaters[0].model.fanCoolingRate}
            alankilianundefined ComedianTF2undefined 2 Replies Last reply Reply Quote 2
              alankilian @infiniteloop
              @infiniteloop
              Brilliant!
              Where did you find that in the documentation?
                infiniteloop @alankilian
                @alankilian
                In GCode Meta Commands under Binary infix operators - there, the caret is the last entry in the table.
                  ComedianTF2 @infiniteloop
                  @infiniteloop That did the trick. Much appreciated for that insight.
                  Final code:
                  echo >"0:/sys/config_PID_tune_E0.g" "M307 H0 R"^{heat.heaters[0].model.heatingRate}, "K"^{heat.heaters[0].model.coolingRate}^":"^{heat.heaters[0].model.fanCoolingRate}, "D"^{heat.heaters[0].model.deadTime}, "E"^{heat.heaters[0].model.coolingExp}
                  That macro resulted in this config_PID_tune_E0.g
                  M307 H0 R1.990 K0.292:0.075 D4.7 E1.4
                  • dc42undefined dc42 marked this topic as a question
