    Only probe where the part will be printed
    51
    3.8k
      jay_s_uk @RatRig0331
      @ratrig0331 the most probe points you can have on a duet 2 are 121 and on a duet 3 are 441
      RatRig0331undefined 1 Reply Last reply Reply Quote 0
      • RatRig0331undefined
        RatRig0331 @jay_s_uk
        @jay_s_uk too many points isn’t the issue I think, it must be too few points? With the settings first told to me it wanted to do a 13x12 grid on a 100mmx100mm print 156 points total, than I changed the min max to 50/100 and it only probed the middle and 4 conners and gave the same error
        OwenDundefined dc42undefined 2 Replies Last reply Reply Quote 0
        • OwenDundefined
          OwenD @RatRig0331
          @ratrig0331
          I believe the problem you are having is that I didn't allow for a probe that was offset to the other side of the extruder to mine.
          Try these files.
          I think it should sort it out.
          ;setDefaultProbePoints.g - to be called from config.g after Z probe configuration section and any time defaults need to be reset.
          var SafeZone = 10 ; probing won't be done closer than this amount from bed edge - adjust as required
          var defaultProbeSpacing = 50 ; default mesh grid spacing in mm - adjust as required
          ; shouldn't need to edit after here
          var MinReachableX = max(0,sensors.probes[0].offsets[0]) + var.SafeZone
          var MaxReachabeX = move.axes[0].max - abs(sensors.probes[0].offsets[0]) - var.SafeZone
          var MinReachableY =  max(0,sensors.probes[0].offsets[1]) + var.SafeZone
          var MaxReachabeY = move.axes[1].max - abs(sensors.probes[0].offsets[1]) - var.SafeZone
          M557 X{var.MinReachableX,var.MaxReachabeX} Y{var.MinReachableY,var.MaxReachabeY} S{var.defaultProbeSpacing}; define mesh grid
          ;echo "M557 X"^{var.MinReachableX}^","^{var.MaxReachabeX}, "Y"^{var.MinReachableY}^","^{var.MaxReachabeY}, "S"^{var.defaultProbeSpacing}
          if !exists(global.minProbeX)
          	global minProbeX = move.compensation.probeGrid.mins[0]
          else
          	set global.minProbeX = move.compensation.probeGrid.mins[0]
          if !exists(global.minProbeY)
          	global minProbeY = move.compensation.probeGrid.mins[1]
          else
          	set global.minProbeY = move.compensation.probeGrid.mins[1]
          if !exists(global.maxProbeX)
          	global maxProbeX = move.compensation.probeGrid.maxs[0]
          else
          	set global.maxProbeX = move.compensation.probeGrid.maxs[0]
          if !exists(global.maxProbeY)
          	global maxProbeY = move.compensation.probeGrid.maxs[1]
          else
          	set global.maxProbeX = move.compensation.probeGrid.maxs[1]
          revised mesh.g
          ;0:/sys/mesh.g
          ; run when G29 with no paramters is called.
          ; if this file not found G29 S0 will run
          var SafeZone = 3 ; safety margin for probing near edge.
          var MinSpace = 20 ; put default minimum spacing
          var MaxSpace = 60 ; put default maximum spacing
          ; these values are place holders aand will be calculated later
          var m557MinX = 40;  ; put your default here
          var m557MaxX = 180;  ; put your default here
          var m557MinY = 20;  ; put your default here
          var m557MaxY = 180;  ; put your default here
          var ProbeCenterX = 90 ; will be updated to probe centre of print
          var ProbeCenterY = 90 ; will be updated to probe centre of print
          var ProbeNumX = 8 ; put default number of probe points
          var ProbeNumY = 8 ; put default number probe points.
          var MaxProbePoints = max(floor(move.axes[0].max / var.MaxSpace),floor(move.axes[1].max / var.MaxSpace)) ; maximum points in either axis
          ;echo "Maximum allowed probe points is " ^ var.MaxProbePoints ^ " using max space of " ^ var.MaxSpace
          if exists(global.minProbeX)
          	if global.minProbeX < max(0,sensors.probes[0].offsets[0]) + var.SafeZone
          		echo "minProbeX (" ^ global.minProbeX ^ ") unreachable - reset to " ^ (sensors.probes[0].offsets[0] + var.SafeZone)
          		set global.minProbeX = max(0,sensors.probes[0].offsets[0]) + var.SafeZone
          	set var.m557MinX = global.minProbeX
          if exists(global.maxProbeX)
          	if global.maxProbeX < (global.minProbeX + (var.MinSpace*2))
          		set global.maxProbeX = (global.minProbeX + (var.MinSpace*2))
          	if global.maxProbeX > (move.axes[0].max - abs(sensors.probes[0].offsets[0]) - var.SafeZone)
          		echo "maxProbeX (" ^ global.maxProbeX ^ ") unreachable - reset to " ^ (move.axes[0].max - sensors.probes[0].offsets[0] - var.SafeZone)
          		set global.maxProbeX = move.axes[0].max - abs(sensors.probes[0].offsets[0]) - var.SafeZone
          	set var.m557MaxX = global.maxProbeX
          if exists(global.minProbeY)
          	if global.minProbeY < max(0,sensors.probes[0].offsets[1]) + var.SafeZone
          		echo "minProbeY (" ^ global.minProbeY ^ ") unreachable - reset to " ^ (sensors.probes[0].offsets[1] + var.SafeZone)
          		set global.minProbeY = max(0,sensors.probes[0].offsets[1]) + var.SafeZone
          	set var.m557MinY = global.minProbeY
          if exists(global.maxProbeY)
          	if global.maxProbeY < (global.minProbeY + (var.MinSpace*2))
          		set global.maxProbeY = (global.minProbeY + (var.MinSpace*2))
          	if global.maxProbeY > (move.axes[1].max - abs(sensors.probes[0].offsets[1]) - var.SafeZone)
          		echo "maxProbeY (" ^ global.maxProbeY ^ ") unreachable - reset to " ^ (move.axes[1].max - sensors.probes[0].offsets[1] - var.SafeZone)
          		set global.maxProbeY = (move.axes[1].max - abs(sensors.probes[0].offsets[1]) - var.SafeZone)
          	set var.m557MaxY = global.maxProbeY
          echo "Probing grid - X" ^ var.m557MinX ^ ":" ^ var.m557MaxX ^ " Y" ^ var.m557MinY ^ ":" ^ var.m557MaxY
          var MinProbesX = floor((var.m557MaxX - var.m557MinX) / var.MaxSpace)
          ;echo "Min Probes X is " ^ var.MinProbesX
          var MaxProbesX = floor((var.m557MaxX - var.m557MinX) / var.MinSpace)
          ;echo "Max Probes X is " ^ var.MaxProbesX
          set var.ProbeNumX = min(var.MaxProbePoints,var.MaxProbesX)
          var MinProbesY = floor((var.m557MaxY - var.m557MinY) / var.MaxSpace)
          ;echo "Min Probes Y is " ^ var.MinProbesY
          var MaxProbesY = floor((var.m557MaxY - var.m557MinY) / var.MinSpace)
          ;echo "Max Probes Y is " ^ var.MaxProbesY
          set var.ProbeNumY = min(var.MaxProbePoints,var.MaxProbesY)
          ; sanity check probe points
          if var.ProbeNumX<2
          	set var.ProbeNumX=2
          if var.ProbeNumY<2
          	set var.ProbeNumY=2
          if var.ProbeNumX > var.MaxProbePoints
          	set var.ProbeNumX = var.MaxProbePoints
          if var.ProbeNumY > var.MaxProbePoints
          	set var.ProbeNumY = var.MaxProbePoints
          if (var.ProbeNumX * var.ProbeNumY) > 441
          	if var.ProbeNumX > 21
          		set var.ProbeNumX = 21
          		echo "Too many X points - reduced to 21"
          	if var.ProbeNumY > 21
          		set var.ProbeNumY = 21
          		echo "Too many Y points - reduced to 21"
          echo "Probing " ^ var.ProbeNumX ^ " points in X direction & " ^ var.ProbeNumY ^ " points in Y direction"
          ;check state of heaters
          var bedState = heat.heaters[0].state
          var bedActiveTemp = heat.heaters[0].active
          var bedStandbyTemp = heat.heaters[0].standby
          var nozzleState = heat.heaters[1].state
          M140 P0 S-276 ; turn off bed heater
          M568 P0 A0 ; turn off nozzle heater
          ; do probing
          set var.ProbeCenterX = (global.maxProbeX - ((global.maxProbeX - global.minProbeX)/2)) ; calculate centre point of probe area
          set var.ProbeCenterY = (global.maxProbeY - ((global.maxProbeY - global.minProbeY)/2)) ; calculate centre point of probe area
          echo "Setting Z datum point at X" ^ var.ProbeCenterX ^ " Y" ^ var.ProbeCenterY
          ; set Z = 0 to centre of probe area
          G1 X{var.ProbeCenterX- sensors.probes[0].offsets[0]} Y{var.ProbeCenterY- sensors.probes[0].offsets[1]} Z{sensors.probes[0].diveHeight+2} F3600
          G30
          echo "Mesh probing"
          M557 X{var.m557MinX,var.m557MaxX} Y{var.m557MinY,var.m557MaxY} P{var.ProbeNumX,var.ProbeNumY}
          if result != 0
          	abort "ERROR: could not create mesh"
          else
          	G29 S0
          	if result != 0
          		abort "ERROR: Mesh probing failed"
          	else
          		echo "Mesh probing successful.   Loading mesh.."
          echo "Reset Z datum in mesh centre"
          G1 X{var.ProbeCenterX - sensors.probes[0].offsets[0]} Y{var.ProbeCenterY - sensors.probes[0].offsets[1]} Z{sensors.probes[0].diveHeight+2} F3600
          G30
          ; turn the heaters back on if needed
          if var.bedState != "off"
          	M140 S{var.bedActiveTemp} R{var.bedStandbyTemp}
          	if var.bedState="active"
          		M144 P0 S1 ; put bed on active temp
          	else
          		M144 P0 S0 ; put bed on standby temp
          if var.nozzleState	!= "off"
          	if var.nozzleState = "active"
          		M568 P0 A2 ; set nozzle to active
          	else
          		M568 P0 A1 ; set nozzle to standby
            dc42 administrators @RatRig0331
            @ratrig0331 the minimum spacing between points allowed is 0.1mm in each of X and Y. "Spacing too small" means you have tried to specify a smaller spacing than that.
            OwenDundefined 1 Reply Last reply Reply Quote 1
            • OwenDundefined
              OwenD @dc42
              @dc42 said in Only probe where the part will be printed:
              In that case I'm at a bit of a loss how @RatRig0331 is getting that error using my code.
              It's early morning here (Australia) and I have to go to work, so I can't look at till I get home.
              @RatRig0331 Can you please un-comment all the lines in the mesh.g that show the calculations and post the output from the console.
              At the start I work out the maximum possible number of probes if a full bed was done using maxSpace.
              Later I use the object size to recalculate the number of probes also using maxSpacing.
              The lesser of these two numbers is used (or should be).
              There must be a fundamental flaw in my logic (at least with your bed size and probe configuration). 😕
              It also occurs to me that I haven't catered for deltas or printers where X0, Y0 is in the center of the bed.
              RatRig0331undefined 2 Replies Last reply Reply Quote 1
                RatRig0331 @OwenD
                @owend
                8/15/2022, 8:04:58 PM Error: M557: bad grid definition: Spacing too small
                8/15/2022, 8:04:26 PM Reset Z datum in mesh centre
                8/15/2022, 8:04:26 PM Mesh probing successful. Loading mesh..
                8/15/2022, 8:04:26 PM 36 points probed, min error -0.141, max error 0.093, mean -0.020, deviation 0.066
                Height map saved to file 0:/sys/heightmap.csv
                8/15/2022, 8:01:59 PM Mesh probing
                8/15/2022, 8:01:50 PM Setting Z datum point at X250.0000 Y250.0000
                8/15/2022, 8:01:50 PM Probing 6 points in X direction & 6 points in Y direction
                8/15/2022, 8:01:50 PM Probing grid - X183.907:316.093 Y188.907:311.093
                8/15/2022, 8:01:32 PM Leadscrew adjustments made: -0.014 0.008 0.009, points used 3, (mean, deviation) before (0.001, 0.010) after (-0.000, 0.000)
                8/15/2022, 8:01:12 PM Leadscrew adjustments made: 0.015 0.022 0.001, points used 3, (mean, deviation) before (0.014, 0.008) after (-0.000, 0.000)
                8/15/2022, 8:00:52 PM Leadscrew adjustments made: 0.102 0.033 -0.002, points used 3, (mean, deviation) before (0.046, 0.040) after (0.000, 0.000)
                8/15/2022, 8:00:32 PM Leadscrew adjustments made: 0.503 0.279 0.452, points used 3, (mean, deviation) before (0.404, 0.087) after (-0.000, 0.000)
                8/15/2022, 7:58:35 PM M32 "0:/gcodes/First_Layer_Test_0.2mm_PLA_10mhhhhhhhhhhhhhh.gcode"
                File 0:/gcodes/First_Layer_Test_0.2mm_PLA_10mhhhhhhhhhhhhhh.gcode selected for printing
                  RatRig0331 @OwenD
                  @owend
                  8/15/2022, 8:17:42 PM Error: M557: bad grid definition: Spacing too small
                  8/15/2022, 8:17:10 PM Reset Z datum in mesh centre
                  8/15/2022, 8:17:10 PM Mesh probing successful. Loading mesh..
                  8/15/2022, 8:17:10 PM 36 points probed, min error -0.105, max error 0.079, mean -0.005, deviation 0.044
                  8/15/2022, 8:14:43 PM Mesh probing
                  8/15/2022, 8:14:34 PM Setting Z datum point at X250.0000 Y250.0000
                  8/15/2022, 8:14:34 PM Probing 6 points in X direction & 6 points in Y direction
                  8/15/2022, 8:14:34 PM Max Probes Y is 6
                  8/15/2022, 8:14:34 PM Min Probes Y is 2
                  8/15/2022, 8:14:34 PM Max Probes X is 6
                  8/15/2022, 8:14:34 PM Min Probes X is 2
                  8/15/2022, 8:14:34 PM Probing grid - X183.907:316.093 Y188.907:311.093
                  8/15/2022, 8:14:34 PM Maximum allowed probe points is 8 using max space of 60
                  8/15/2022, 8:14:16 PM Leadscrew adjustments made: 0.002 0.008 0.006, points used 3, (mean, deviation) before (0.005, 0.002) after (0.000, 0.000)
                  8/15/2022, 8:13:56 PM Leadscrew adjustments made: 0.016 0.016 0.011, points used 3, (mean, deviation) before (0.015, 0.002) after (0.000, 0.000)
                  8/15/2022, 8:13:36 PM Leadscrew adjustments made: 0.168 0.055 0.022, points used 3, (mean, deviation) before (0.084, 0.057) after (-0.000, 0.000)
                  8/15/2022, 8:13:16 PM Leadscrew adjustments made: 0.413 0.322 0.388, points used 3, (mean, deviation) before (0.372, 0.035) after (0.000, 0.000)
                  8/15/2022, 8:12:01 PM M32 "0:/gcodes/First_Layer_Test_0.2mm_PLA_10mhhhhhhhhhhhhhh.gcode"
                  OwenDundefined 1 Reply Last reply Reply Quote 0
                  • OwenDundefined
                    OwenD @RatRig0331
                    @ratrig0331
                    The M557 that is causing the error seems to be well after all the stuff I did.
                    Check for an M557 somewhere else in your slicer start gcode
                    RatRig0331undefined 2 Replies Last reply Reply Quote 0
                      RatRig0331 @OwenD
                      @owend
                      your right sorry it was in my start code purge line for some reason thank you so much for your time and patients with me this is all still vary new to me
                      8/15/2022, 9:22:31 PM Reset Z datum in mesh centre
                      8/15/2022, 9:22:31 PM Mesh probing successful. Loading mesh..
                      8/15/2022, 9:22:31 PM 36 points probed, min error -0.174, max error 0.083, mean -0.012, deviation 0.067
                      8/15/2022, 9:20:04 PM Mesh probing
                      8/15/2022, 9:19:56 PM Setting Z datum point at X250.0000 Y250.0000
                      8/15/2022, 9:19:55 PM Probing 6 points in X direction & 6 points in Y direction
                      8/15/2022, 9:19:55 PM Max Probes Y is 6
                      8/15/2022, 9:19:55 PM Min Probes Y is 2
                      8/15/2022, 9:19:55 PM Max Probes X is 6
                      8/15/2022, 9:19:55 PM Min Probes X is 2
                      8/15/2022, 9:19:55 PM Probing grid - X183.907:316.093 Y188.907:311.093
                      8/15/2022, 9:19:55 PM Maximum allowed probe points is 8 using max space of 60
                      8/15/2022, 9:19:55 PM Leadscrew adjustments made: -0.003 0.011 0.016, points used 3, (mean, deviation) before (0.007, 0.007) after (-0.000, 0.000)
                      8/15/2022, 9:19:34 PM Leadscrew adjustments made: 0.006 -0.003 0.004, points used 3, (mean, deviation) before (0.002, 0.003) after (0.000, 0.000)
                      8/15/2022, 9:19:14 PM Leadscrew adjustments made: 0.046 0.021 0.031, points used 3, (mean, deviation) before (0.032, 0.009) after (-0.000, 0.000)
                      8/15/2022, 9:18:54 PM Leadscrew adjustments made: -0.011 0.368 0.277, points used 3, (mean, deviation) before (0.213, 0.149) after (-0.000, 0.000)
                        RatRig0331 @OwenD
                        @owend
                        sorry one more question so far every time the start code hits your lines the hotend and bed turn off during the mesh than back on after. i tryed moving some things around but it still turns off all heaters during the mesh. here is my full start code
                        BED_TEMP=[first_layer_bed_temperature]
                        G90 ; use absolute coordinates
                        M83 ; extruder relative mode
                        M140 S[first_layer_bed_temperature] ; set final bed temp
                        M104 S150 ; set temporary nozzle temp to prevent oozing during homing and auto bed leveling
                        G4 S10 ; allow partial nozzle warmup
                        G28 ; home all axis
                        G1 Z50 F240
                        G1 X50 Y50 F3000
                        M116 ; Wait for all temps to stabilise
                        G32; (TRIM BED)
                        G32; (TRIM BED)
                        G32; (TRIM BED)
                        G32; (TRIM BED)
                        ;;;;;;auto probe print area only;;;;;;
                        set global.minProbeX = {first_layer_print_min[0]}
                        set global.maxProbeX = {first_layer_print_max[0]}
                        set global.minProbeY = {first_layer_print_min[1]}
                        set global.maxProbeY = {first_layer_print_max[1]}
                        G29 ; do mesh for printed area
                        G29 S1 ; load small mesh
                        G01 X0 Y{"{move.axes[1].max}"} Z0.6 F1500 ; Move to back corner while heating
                        M568 P{current_extruder} R{"{heat.coldExtrudeTemperature+5}"} S{first_layer_temperature[current_extruder]} A2 ; (set standby and active temperatures for active tool. Standby is 5 degrees above cold extrude temp )
                        ;;;;final temp and purge line;;;;
                        M104 S{first_layer_temperature[initial_extruder]+extruder_temperature_offset[initial_extruder]} ; set final nozzle temp
                        M190 S[first_layer_bed_temperature] ; wait for bed temp to stabilize
                        M109 S{first_layer_temperature[initial_extruder]+extruder_temperature_offset[initial_extruder]} ; wait for nozzle temp to stabilize
                        G1 Z2.0 F3000; (MOVE Z AXIS UP LITTLE)
                        G1 X0.1 Y20 Z0.35 F5000.0; (MOVE TO PURDGE START)
                        G1 X0.1 Y200.0 Z0.35 F1500.0 E25; (DRAW FIRST LINE)
                        G1 X0.4 Y200.0 Z0.35 F5000.0; (MOVE TO THE SECOND LINE)
                        G1 X0.4 Y20.0 Z0.35 F1500.0 E30; (DRAW SECOND LINE)
                        G92 E0; (EXTRUDER RESET)
                        OwenDundefined 2 Replies Last reply Reply Quote 0
                        • OwenDundefined
                          OwenD @RatRig0331
                          @ratrig0331
                          The turning off of the heaters is deliberate and is done in mesh.g
                          I find that the accuracy of my bltouch suffers if they are on when probing
                          I run a 240v bed.
                          I'll have a look later and add an option to not turn off heaters.
                            dc42 administrators @OwenD
                            @owend you can turn off heaters temporarily during probing by using the B1 parameter in your M558 command.
                            • OwenDundefined
                              OwenD @dc42
                              Roger that..
                              That makes that section of code superfluous.
                              Does it turn off the bed heater as well?
                              • OwenDundefined
                                OwenD @RatRig0331
                                @ratrig0331 said in Only probe where the part will be printed:
                                You can remove these lines in your slicer as you have set your temps elsewhere in your start code.
                                This version removes all the code related to heating from mesh.g
                                ;0:/sys/mesh.g
                                if var.ProbeNumX<2
                                	set var.ProbeNumX=2
                                if var.ProbeNumY<2
                                	set var.ProbeNumY=2
                                ; do probing
                                G30
                                echo "Mesh probing"
                                if result != 0
                                else
                                	G29 S0
                                	if result != 0
                                	else
                                G30
                                • OwenDundefined
                                  OwenD
                                  @RatRig0331
                                  While I was thinking about how to make these macros "universal" to suit all sorts of configurations, it occurred to me that they had, over time, grown ever more complicated with little benefit.
                                  Bed sizes and the probe positions don't tend to change after all.
                                  I have therefore decided to simplify things.
                                  I still call "setDefaultProbePoints.g" from config.g and anywhere else I might want to set the mesh for the entire bed.
                                  Rather than me trying to calculate the area that can be probed, you just enter your M557 just as you would normally do in config.g
                                  M557 X10:470 Y10:470 P6 ; set values as you would normally do in config.g
                                  In superslicer, rather than call G29, I call mesh.g using M98, but pass the parameters for the min/max print values and the distance between probe points
                                  A=xMin of print area
                                  B=xMax of print area
                                  C=yMin of print area
                                  D=yMax of print area
                                  N=distance between probe points (equivalent to S parameter in M557)
                                  M98 P"0:/sys/mesh.g" A{first_layer_print_min[0]} B{first_layer_print_max[0]} C{first_layer_print_min[1]} D{first_layer_print_max[1]} N30 ; set N to your desired distance between points
                                  In mesh.g I check if all those parameters have been passed.
                                  If they have, I do the small mesh.
                                  If they haven't I reload the defaults and probe the full bed.
                                  Therefore if you send G29 or select mesh probing in DWC it will do the entire bed even if you forget to reset the defaults.
                                  ;mesh.g
                                  M98 P"setDefaultProbePoints.g"
                                  if (exists(param.A) && exists(param.B) && exists(param.C) && exists(param.D) && exists(param.N))
                                  	M557 X{max(move.compensation.probeGrid.mins[0],param.A),min(move.compensation.probeGrid.maxs[0],param.B)} Y{max(move.compensation.probeGrid.mins[1],param.C),min(move.compensation.probeGrid.maxs[1] ,param.D)} S{param.N}
                                  	if result != 0
                                  		abort "Invalid M557 parameters"
                                  G29 S0
                                  If you wanted to set the number of probe points rather than the distance between them just change S{param.N} to P{param.N} in the M557 line in mesh.g
                                  • oozeBotundefined
                                    oozeBot
                                    This might be useful: https://forum.duet3d.com/topic/29647/you-down-with-opp-oozebot-post-processor
                                      @owend said in Only probe where the part will be printed:
                                      Roger that..
                                      Yes, it turns all heaters off. In the past it's been the bed heater that causes most of the problems for Z probes, however I suspect that with Revo and similar hot ends the hot end heater might affect Z probes too because of the higher magnetic field they are likely to produce.
                                        RatRig0331 @OwenD
                                        @owend I’m getting some mix results with the bed mesh either works out great or works out horrible with driving my nozzle right into the bed I don’t know is doing a 3 point axis bed level is messing with the bed mesh or the last z offset probe touch
                                        • OwenDundefined
                                          OwenD @RatRig0331
                                          @ratrig0331
                                          There's nothing in the code which can cause intermittent faults such as that you describe.
                                          The problem is either wiring related, electrical interference , or a faulty BlTouch.
                                          You can check if the BlTouch is in an error state or already deployed using the object model, but this only serves to allow you to cancel the process.
                                          You need to find the root cause.
                                          You need to provide details of what is happening exactly. What lights are on the BlTouch. What messages appear in DWC
                                          It's probably better to start a new thread.
                                            RatRig0331 @OwenD
                                            @owend I have a Theory to why it’s crashing. My 3 point bed leveling before the new smaller mesh on my 500x500mm bed is just too much of a difference from the outter most points of the bed level to the new inner smaller point bed mesh. I manually moved the three probe points much closer the the center and the mesh looks quite a bit better as well as flatter with less extreams. My z changed quite a bit with this new bed level as well by almost .45mm.
                                            Is there a way to auto ajust the bed level points to be in the same area of the auto bed mesh?
