Solved Update interrupted
Update has not failed, but my ssh connection to the printer is lost. The update was in the part of removing the old files . Is there any way I can connect again or should I just wait for the update to finish by its own? Or: it will finish if my ssh console lost the conection to my laptop?
Update was being done useing sudo apt update / sudo apt upgrade for upgrading from 3.3 to 3.4.1 version, duet3 board in SBC mode
Are you still able to ping the pi?
How long has it been?
@phaedrux 1 hs so far, ping is not responding
I guess it is dead? Im afraid to reboot jajajajaja -
Can you connect a display and local keyboard up to it to see if it's actually hung?
@tinchus just reboot. Should be fine
Thanks both. Yes, I had the local display, wich turned black after loosing the ssh connection.
I rebooted, it booted on 3.3 version. Then I repeated the comand in ssh and I got a "resume" message, wich worked ok. Thanks! -
