    Question: BL Touch Probe Offset & Mesh Bed Leveling
    • wieman01undefined
      wieman01
      I hope this is an easy one... I am using a BL-Touch as proximity sensor and have configured a XY-Offset as it sits in front of the nozzle:
      G31 P25 X0 Y-36 Z1.100
      These are the axis limits:
      M208 X0:480 Y0:350 Z0:260 S1
      Z probe has been calibrated using the center point of my print bed (X240, Y175).
      This is how I invoke mesh bed leveling:
      G32
      M557 X0:480 Y0:350 P5:4 		; probing points for mesh bed compensation
      G29 S2					; clear height map
      G29 S0 					; run mesh bed compensation procedure & save map
      Now my question is how I should account for the Y-Offset (G31) of the BL-Touch (36mm). Should I increase the first Y-value by 36mm (Y36:350) or should I reduce the second value (i.e. Y0:314)?
      Thank you for your help!
      wieman01
      BoAundefined CCS86undefined 2 Replies Last reply Reply Quote 0
      • BoAundefined
        BoA @wieman01
        @wieman01 Y range is limited only from one side. Y=0 coordinates can be reached by bltouch - it just moves nozzle to position Y=36, and then proble is at Y=0.
        But.. if nozzle can go only to Y=350, then probe can reach only points with Y <= 350-36.
        So M557 would have Y range Y0:314, as any higher Y is out of reach of probe tip.
        wieman01undefined 1 Reply Last reply Reply Quote 2
        • CCS86undefined
          CCS86 @wieman01
          Add the offset to your grid definition. So, you could run Y-36:314, but would likely run Y0:314, since you can't print below Y0.
          • wieman01undefined
            wieman01 @BoA
            @boa said in Question: BL Touch Probe Offset & Mesh Bed Leveling:
            Thank you, that makes sense. I'll change the settings accordingly. This could be reason why bed leveling appears to be slightly off.
