    he MCU temperature is specified with negative values
    • axiomundefined
      axiom
      My board gets 24 V in (just measured again) but only 17 V is displayed in the console. In addition, the MCU temperature is specified with negative values. What can be the reason?
      axiomundefined 1 Reply Last reply Reply Quote 0
      • axiomundefined
        axiom @axiom
        @axiom when i unplug the display..the display is quite normal
          @axiom I think you have plugged the display into the wrong 10-way ribbon cable connector. On the Duet 2 it should be in CONN_SD.
          • axiomundefined
            axiom @dc42
            @dc42 Well, "if you can read, you have a clear advantage" (German saying).... i was stupid... thanks, that was the solution!
