duet 3 6hc and raspberry p3b+
@sgk i have this.
What version of firmware does it have now?
Did you update on the Pi?
What version of DWC does it show it has? -
@phaedrux Board: Duet 3 MB6HC (MB6HC)
DSF Version: 3.4.1
Firmware: RepRapFirmware for Duet 3 MB6HC 3.1.1 (2020-05-19b2) -
I did the update with pi but now the motors don't work very well and the fans still don't work says it all
@phaedrux that's when I do home x and the same for home yvideo 2.mp4
@sgk said in duet 3 6hc and raspberry p3b+:
DSF Version: 3.4.1
Firmware: RepRapFirmware for Duet 3 MB6HC 3.1.1 (2020-05-19b2)You have a mismatch. When the pi updated the duet firmware didn't get updated at the same time. Please send M997 to initiate a manual firmware update and then check again with M115.
@phaedrux 27/08/2022 00:28:39 m115
FIRMWARE_NAME: RepRapFirmware for Duet 3 MB6HC FIRMWARE_VERSION: 3.4.1 ELECTRONICS: Duet 3 MB6HC v1.01 or later FIRMWARE_DATE: 2022-06-01 21:09:12
27/08/2022 00:28:22 Connection established
27/08/2022 00:28:22 CORS disabled
27/08/2022 00:28:22 Error: M552: Network-related commands are not supported when using an attached Single Board Computer
27/08/2022 00:28:16 m997
27/08/2022 00:21:32 Connection established -
Ok, so now when you send M122 you should see matching firmware and DCS versions of 3.4.1.
Now in DWC can you check the DWC version?
@phaedrux
it stays like that -
Look in the general and machine specific tabs on the left side near the bottom
DSF Version: 3.4.1
Firmware: RepRapFirmware for Duet 3 MB6HC 3.4.1 (2022-06-01) -
And the DWC version?
@phaedrux Duet Web Control 3.4.1
GitHub
Web Interface developed by Christian Hammacher for Duet3D.
Licensed under the terms of the GNU General Public License v3 -
Ok great, you are all matched up.
Now I would carefully go through the commissioning guide and test pieces of hardware one at a time. Double check wiring. Get out a multimeter if need be.
@phaedrux thank you i will do my best thank you so much
